NEW BKD ENGINE NEEDED
tdi-man Feb 2, 2013
  1. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    after i good place to surply and fit a recon engine 2.0 TDI 140 BKD
    any body ?
    thanks
  2. sliced
    sliced Drive safe, stay alive.
    1,559
    334
    hey mate have a look here
    2.0 bkd | eBay
    you could always source an engine from breakers and get a mechanic to fit?!
  3. tdi-man
    1,783
    64
  4. A1DEYB
    A1DEYB Well-Known Member
    1,682
    43
    Has it gone pop?
  5. tdi-man
    1,783
    64
    LOL
    no its all good apart from it smokes a bit when u been on a run and leave it for a while and start it again.
  6. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,075
    62
    That's what mine does too occasionally.
  7. mike foster
    3,967
    I think you'll find that it's soot blowing out, not smoke ! They all do it eventually but it doesn't signify a knackered engine !
  8. camscockle20vT
    camscockle20vT The stigs ugly brother
    1,740
    77
    Get your egr valve checked and cleaned, its the usual culprite.
  9. tdi-man
    1,783
    64
    after speaking to loads of people im thinking of letting a local engine rebuild company remove my head and recon it and also recon the block while still in car as its not needed to be removed.
    do pistons need to be rebored and oversized if car has done 200,000 milles with full long life history as u cant tell untill remove head but alot of people so NO ????
  10. Boon
    Boon Active Member
    441
    59
    New piston rings and de-glaze the cylinders would be advisable if your going to strip it down that much
    Shouldn't need to 'bore-out' them
  11. tdi-man
    1,783
    64
    great thanks thats what ive been told ;)
  12. Boon
    Boon Active Member
    441
    59
    So has your BKD done 200k? There is hope for mine yet! (119k & just stage 1 map with EGR delete & also hot start fix map)
  13. shady-ninja
    shady-ninja Active Member
    999
    53
    im sure you can do better than £1750.
    shop arond to bypass the middle men
    and get your engine rebuilt.
    but you havent told us any thing
    about the milage of your car.
  14. JACK-TDI
    JACK-TDI New Member
    Get the 170bhp version fitted :)
  15. tdi-man
    1,783
    64
    yes m8 going to local engine rebuild firm they will do mine for 500-600 plus vat plus my m8 needs to take head of and use his ramps
  16. shady-ninja
    999
    53
    not worth it as the ECU and other things have to changed.
    just get someone to rebuild the engine.
