New Bigger brakes on A3 SB quattro 2.0TFSI S-tronic 2009
A3SBQ May 19, 2012
  1. A3SBQ
    A3SBQ A3 SportBack 2TFSI quattro DSG
    415
    59
    Hi.
    I am about to get me some bigger brakes. Have searched the forum and find only technical info, no easy short versions.
    My car is a 2009 A3 SportBack 2.0TFSI quattro S-tronic.
    It is equipped with the 312x25mm disk at front and 282x12mm at the rear.
    I have found on ebay a complete S3 set front & rear.
    Not sure if it will fit plug&play hens reading about some about the hubs being different on some models. Can some one shed some light into this? Does it help that mine is a quattro?
    eBay - The UK's Online Marketplace
    I have also found a set from the TTRS. Its a bit more expensive but should look great and make the car stop not only once but always.
    Audi TTRS Bremsen TT RS Bremsensatz für Audi S3 TT A3 inkl. Einbau | eBay
    My plan is to use the care on track days and off course the show factor is pleasant too.
    Since my car is stock 200Bhp and will only get a stage 1 tune it will newer reach over 250Bhp and the S3 have 265Bhp as stock. Will the S3 brakes hold for my car? Have read some wear here that the stock S3 brakes are no better than the looks?? is this true?
    I thanks all for the help on this good forum and awaits for the feed back.
    PS. If some one has a different solution that will work as a bolt on plug&play kit I appreciate this too. A 6pot setup is of no interest to me.
  2. A3SBQ
    415
    59
    Bump
    Any one!!:think:
  3. mjr901
    mjr901 Parts Manager - (Main Dealer) Gold Supporter Audi S3 Audi Main Dealer
    3,597
    1,067
    if I remember rightly. S3 fronts are 345mm at front. These will be fine for the horses your running. I don't struggle with 310bhp ish.
    I think your brakes will be the same as the Mk5 golfs? someone correct me?
    If so this upgrade is very popular. straight swap... any bigger though I think the master cylinder will need to be updated.
  4. A3SBQ
    415
    59
    Thanks for the reply.
    So this mean that the standard S3 kit i found on ebay fits without any problems?
  5. mjr901
    3,597
    1,067
    I cannot give you a definitive answer. but I know of a guy called "dave" who will know for sure. Other than that "N8" might know. ("N8" knows dave i believe)
    or "MartayMcFly" had some carriers from dave. he'll have his details.
    Theres loads of others that's will know the definitive answer too!
    look for the Mk5 R32 brakes too. they the same. often cheaper, and a lovely blue colour!
  6. bootneck_max
    bootneck_max Member
    77
    Tbh, your better off replacing the brake lines with steel braided lines, upgraded brake pads and replace the brake fluid with a better fluid. This is the cheapest way and probably as good! Especially if your gonna track you car. and then when you do track it, and if it's not up to scratch you can go for the whole upgrade. And you'll already have the upgraded brake lines! :)
  7. A3SBQ
    415
    59
  8. Kelza
    Kelza MODERATOR Staff Member Moderator Audi RS3
    3,074
    601
  9. bootneck_max
    bootneck_max Member
    77
    Fair one mate, if its a bit of bling your after go for it! Those cupra brembos look decent, especially after a good clean!! :) seem a bit dear tho??
  10. mjr901
    3,597
    1,067
    there the 1.8 20v Cupra ones I think ie the old Cupra.
    look for the 345mm ones.
  11. A3SBQ
    415
    59
    When do I need to upgrade the master cylinder?
  12. Kelza
    3,074
    601
    Only if you go bbk 6, or 8 pot brakes ,but some 6 pots will be fine like the vw racing set up...
  13. crunchie
    crunchie Active Member
    880
    77
    Don't pay any extra for TTS ones as they are exactly the same as S3 ones.
    My pal has just fitted S3 ones with SS lines to his ED30(also 312mm) and he is noticing a big improvement.
    His master cylinder might be larger as standard tho but I'm unsure.
  14. Brodster
    Brodster Well-Known Member Team Ibis VCDS Map User Audi S4 Audi Avant Owner Group
    3,548
    882
    I've had no real problems with the standard set up on my S3 running Stage 1. They feel great when I've had to emergency stop...no fade when braking from higher speeds so S3 items should be fine in your car.
  15. S3RYE
    S3RYE Interior Next!!
    3,448
    70
    S3 set up will be fine! dont go TTRS its a waste of moneysssss. Better off to go with VWR or AP for that money!
  16. Ash187
    7,452
    712
    im also interested in the S3 brakes but i need to know what i would need to go from the 2.0TDI 288mm fronts to the 345mm brakes? i heard that the main part i need is the carriers but if i got the whole kit would it just be a bolt on and then bleed brakes to get it all working?
    Also can the cupra brakes be used? i heard they cant for some reason?
    Whats involved in the 4pot brake setup?
  17. Daggerit
    Daggerit Well-Known Member
    1,081
    165
    When I had my 2010 170 quattro A3 I upgraded to the S3 brakes. If you get the full caliper and carrier then it's a straight swap on. A quick bleed of the brakes and away you go, only took me about an hour to do. It took away the sudden bite I found when hitting the brakes initially but stopped very well once you push on them a bit harder. :)
  18. Ash187
    7,452
    712
    So which brakes can i use then?
    S3
    R32
    A3 3.2
    Seat Cupra r brembo??
  19. Daggerit
    1,081
    165
    The S3, R32 and 3.2 V6 brakes are all the same as far as I know. As for the Cupra ones, I don't know so don't want to give you the wrong info! :)
  20. mjr901
    3,597
    1,067
    the brembo ones are the old Cupra I believe. Do a search. "brake differences" loads of stuff :)
  21. mjr901
    3,597
    1,067
  22. N8
    17,163
    718
    If you want Audi/Lambo 8pots you'll need to upgrade the MC to the TT-RS one as well for a perfect pedal:
    But the R8 4pots are perfect:
  23. A3SBQ
    415
    59
  24. N8
    17,163
    718
    Cheap as chips :laugh: But calipers are too heavy :wub:
  25. Lil ad9
    Lil ad9 Member
    68
    Any idea of a rough cost of getting a set of th r8 rears fitted to an 8p s3?? Just for the looks alone gotta be worth a few quid
  26. chris.vincent3
    chris.vincent3 Own a BMW now, HOWEVER I still own VCDS! VCDS Map User
    604
    34
    So the master cylinder doen't need to be changed if going to the S3 set-up on a TDi?
  27. N8
    17,163
    718
    What supply & fitted?
    No, you'll be fine. S3 & TDI is the same anyway, I have an S3 M/C for sale ;)
  28. Lil ad9
    Lil ad9 Member
    68
    Yea plz just a rough idea of supply and fitting
  29. N8
    17,163
    718
    PM'd.
  30. Ash187
    7,452
    712
    What do you S3 owners have for discs? do you guys just stay with the OEM ones or change over? i have been looking and found a few companies that do the 345mm front Discs but i dont know how good they are rated as.
    would you guys go for any of these brake discs to make it look better?
    Kinetix - VOLKSWAGEN GOLF R32 MK5 3.2 V6 REAR BREMBO BRAKE PADS AND KINETIX DRILLED DISCS | eBay
    Tarox - Tarox Audi A3 Quattro S3 3.2 345mm 7/03> Front Brake Discs Drilled & Grooved | eBay
    EBC - Front EBC Ultimax Brake Discs AUDI S3 2.0 Turbo 2006- | eBay
  31. Ash187
    7,452
    712
    Anyone??
  32. mjr901
    3,597
    1,067
    Id like to bump this question.
    24k of hard thrashing and my front discs have a lovely lip on them and pads are very almost cooked.
    Was looking at zerosixty discs, but they are expensive :(
    Looking to replace with drilled/grooved.
    Does anyone have any of the above that Ash187 asked about? If so, any good?
  33. S.
    S. Well-Known Member Team Ibis TFSI Owners Group Audi S3 quattro Manual
    1,947
    509
    are you sure your discs need replacing?
  34. mjr901
    3,597
    1,067
    They're not drastically bad, and could probably get a little more out of them, and plan to, probably 2k more.
    I've been pretty hard on these brakes to be fair, done europe, countless harsh harsh braking, all at stage 2, and I feel i may as-well replace them along with new pads.
    I've already bought some Ferodo pads ages ago, and they've jus sat there waiting to go on, but think i'll go the whole hog so i can forget about them for a good while.
    I'll only have to rip everything off further down the line to just replace discs again, and usually its good practice to change pads at the same time, so makes sense to do it all now.
    I've made this my second car now, so when it does get driven, it gets it big time!
    Rears are alright!
    My independent did notice how bad they were and said it would probably have another life out of them, but with large lips, but hey lets treat the girl.
  35. Reload
    Reload Bird is the Word!
    367
    49
    I use the EBC Ultimax discs front / rear with yellowstuff pads and sm quite happy with them.
  36. S.
    1,947
    509
    i've done 45 000 km's on mine, and there's plenty on them. replaced only pads. but now i decided i want to go ttrs 4 pot kit, so soon will have the real stopping power :D
