New alloys wont fit need advice on spacers and nuts
AudiSBE Jul 2, 2012
  1. AudiSBE
    AudiSBE Member
    158
    10
    Hi All
    I have bought some alloys which are the s3 facelift, I believe they also do these for a TT which I think I may have hence the issues fitting, the back 2 are on fine but the front 2 are rubbing so I will need spacers, can you guys advise of the best spacers, what size would be best to get and also where to get them from,
    The alloys are 225 40 R18
    Thanks in advanced
  2. Kelza
    Kelza MODERATOR Staff Member Moderator Audi RS3
    3,078
    605
    Hi mate check the et, and width on the inside of the alloys and post that up...
  3. Brodster
    Brodster Well-Known Member Team Ibis VCDS Map User Audi S4 Audi Avant Owner Group
    3,548
    885
    If its the facelift alloys the offset will be ET56
  4. GNJ_Motorsport
    GNJ_Motorsport Site Sponsor Site Sponsor
    660
    188
    43
    Do you mean they are rubbing on the inside?
    We sell TPI spacers & bolts that are great value but could do with pics and details of the problem before recommending a size.
  5. PH1L
    PH1L Gievf Buckets
    3,851
    40
    not if theyre off the tt or another model
  6. PH1L
    PH1L Gievf Buckets
    3,851
    40
    youll find the et on the back of the alloys
  7. AudiSBE
    AudiSBE Member
    158
    10
    There E52 and the rubbings on the inside there's not enough clearance where the shocks are
  8. Kelza
    3,078
    605
    The width must be 9j?
  9. moag
    moag she's no d-turbo
    821
    35
    10mm spacers
  10. AudiSBE
    AudiSBE Member
    158
    10
    Nice 1 lads ! I was going to try demon tweeks but they will probs be expensive !
  11. AudiSBE
    AudiSBE Member
    158
    10
    Hi all went to demon tweeks 6mm will cover it but the issue is the hub doesn't sit on the car and moves any ideas ? Cheers
  12. PH1L
    PH1L Gievf Buckets
    3,851
    40
    Hubcentric spacers not just spacers lad
  13. nluk100
    nluk100 Active Member
    994
    184
    43
    What size are the alloys? 225 40 18 is the tyre size!
    They must be 18 x 8J or 8.5J - std S3 alloys are 7.5J, TTS rims are 8J.
  14. AudiSBE
    AudiSBE Member
    158
    10
    All on with hubcentric thanks for the help all :)
  15. PH1L
    PH1L Gievf Buckets
    3,851
    40
    Fronts look like they are poking tractor high too
