new alloys, suspension next
johnnevett Feb 9, 2014
  1. johnnevett
    johnnevett Member
    245
    19
    hi all,
    Fitted my new alloys this morning, they are the 19" 'y' spoke alloys from an Audi A5 with ET32
    now I wanted to fit the bilstein B12 kit with sportlines but I think that might be a bit tight now, what do you reckon?
    Front:
    Rear:
  2. Liquidfusion-S3
    Liquidfusion-S3 I fall to peer pressure!
    1,450
    685
    Is that the standard suspension? looks a bit high from the pictures.
  3. johnnevett
    johnnevett Member
    245
    19
    Yeah standard SE suspension mate
  4. SI-W85
    SI-W85 Well-Known Member
    1,321
    351
    Are they 9J wheels? Get some slight stretch on the tyres won't have a problem with whatever suspension you go for.
  5. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User quattro Audi A4 Audi Avant Owner Group TDi
    5,540
    2,481
    Sportline is supposed to be 45-50mm drop I think you may struggle with that if you have the car loaded. The camber increases as the suspension goes down so will give the tyre a bit more clearance but it does look like it would possibly foul.
    As said above going for a narrower tyre will help but if you have good tyres on the car at the moment you would want to keep them.
    You could go for a lower drop as the tyre will be closer to the arch the gap looks smaller, well it does to me anyway.
    The Pro kit is supposedly 25-30mm or try some Eibach springs.
    Fitted them to my SE, Theres some pictures in the build thread.
    Alternatively a set of coilovers will give you the option to set the ride height to what ever level you want. A decent set won't be much different to the cost of the Bilsteins.
    Karl.
    SI-W85 likes this.
  6. johnnevett
    johnnevett Member
    245
    19
    No mate. They are 8.5J
    Just put brand new 255/35/19 tyres on so was looking for a suspension to suit that rather than paying out for new tyres
  7. johnnevett
    johnnevett Member
    245
    19
    Loving the car mate.
    Yeah, after looking at that I think the pro kit would be the safer option.
    Just wondering with the bilstein B12 kit, if the sport shocks are shorter than our standard SE shocks so might get a little more than the 40mm you said you got on standard shocks
  8. johnnevett
    johnnevett Member
    245
    19
    Found this, same car, alloys and tyre size as me with eibach sportlines
    Looks like it could work
    Limeys A4
