New alloys problem
Ash92 May 26, 2013
  1. Ash92
    Ash92 Active Member
    396
    29
    Could any one help me i have just purchased some.new wheels for my 5x112 a4 but the wheels i have bought are 5x100. I dont want to get rid of them so is there any chance of fitting them to the car if so what will i need to fit them. thanks in advance
  2. moggytom
    moggytom Member
    41
    Custom adaptors would work matey
  3. hades-
    9,482
    646
    as above or redrill
  4. NHN
    29,596
    1,782
    Have a read up on wobble bolts.
  5. Ash92
    Ash92 Active Member
    396
    29
    Thank you for the quick reply ill read into them
  6. moggytom
    moggytom Member
    41
    didnt think wobble bolts would allow up to much difference. Thought it was only 2 mm max
  7. hades-
    9,482
    646
    yeah i thought they were 2mm also.
  8. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 saloon Team Akoya TDi
    15,166
    1,126
    Wobble bolts won't work for that amount of gap and I would not trust them as far I can throw them and that's a really long way.
    EDIT: 2mm gap not 12mm. That's bigger than the hole the bolts go in.
  9. NHN
    29,596
    1,782
    I read 110 instead of 100, my mistake :)
    I know someone that's used wobbles without any issues & on fairly good/expensive wheels, but no the difference of 12mm is to much I agree.
  10. ScottD3
    15,166
    1,126
    Everyone I know that has ever used wobble bolts ends up having to regularly tighten them back up cause they wobble loose.
    Get adapters or get them redrilled them. Seems a safer options than something that's designed to bodge wheels on to a car.
    CHEZ likes this.
  11. NHN
    29,596
    1,782
    Mate of mine has no issues at all, such is life.
    However, if it was me, I would just sell & get some that fit correctly, cant be ***** with re-drilling or using adapters.
  12. Ash92
    Ash92 Active Member
    396
    29
    Does any one no where i can get the adaptors from 112 to 100 i can find the ones up in size but not down
  13. ScottD3
    15,166
    1,126
    Ebay and google?
    PCD Wheel Adaptors 5x112 - 5x100 20mm VAG on eBay! ??
    Don't forget to check your ET and clearance.
    Adapters can push your wheels out by 15mm or more, effecting your final ET.
  14. Joe Clooney
    Joe Clooney Member
    57
    Hi mate, I'm in the very same situation as you, trying to fit 5x100 wheels to my b7 avant
    Check the offset of your new wheels. If it is anything around +40, I would think you will get away with buying a set of 15mm adaptors, venom motorsport do them. I bought a set from them, but as my wheels are et35, they were sticking out too far beyond the arches.
    I have gone down the road of redrilling the hubs. It's not an easy road to go however, I've had to buy two new front hubs, as the oem ones don't suit redrilling as there is not enough thickness between the original bolt holes to allow new holes to be drilled in between. Confused yet? I will post pictures of progress tomorrow.
  15. Joe Clooney
    Joe Clooney Member
    57
