new aircon control unit - query
jbcalvin Mar 2, 2011
  1. jbcalvin
    jbcalvin Member
    691
    21
    Hi guys,
    Fitted a new aircon control unit a couple of months ago from e-bay as I had the earlier style unit that only went from 18-26 degrees, this one goes from 16-28 degrees and have a couple of questions.
    1. The button for the heated rear screen does not stay lit and heated screen not working, also noticed that I need to press it to activate the heated mirrors? Basically when I press it, it lights up for 2 secs and then goes out...
    2. Yesterday the econ button was pressed accidentally by the wife and it will now not switch off.
    Any suggestions?
  2. swarcup
    swarcup Well-Known Member
    1,326
    40
    The unit you have fitted is from a b7 and needs a tweek to the rear demist circuit. Woolord has done a full wright-up on what is required. a search on here under rear demist may turn it up.
    The econ light usually indicates one of two things. the first being the system needs regassing or a sensor has broken, both relatively easy to sort. a scan should indicate the sensor if thats the problem
    here it is..found it http://www.audi-sport.net/vb/a4-a4-...44-b7-c-unit-b6-rear-demist-modification.html :detective2:
  3. MarkWizard
    MarkWizard Member VCDS Map User
    198
    Don't let the wife touch anything!
