new A4 1.8T Owner
dplovin Oct 6, 2012
  1. dplovin
    dplovin Member
    416
    just thought id introduce myself to this section, was recently over at the 8L a3/s3 section but had to sell up needed a bigger car.
    always fancied an a4 and now i have one :)
    im abit of a sucker for upgrades/mods got the bug for it from my old S3
    just thought id ask you guys/girls what are you all doing ? or is there anything i should look out for on these cars fault wise.
    well here it is
  2. Oil pickup pipe is prob one of the biggest gremlins of the 1.8t engines
  3. Slinepete
    Slinepete Member
    314
    Nice car looks the same colour as mine yeah oil pickup can kill if its not in the history that its been done might be worth doing it for peace of mind.
  4. dplovin
    dplovin Member
    416
    ill have a look at that tommorow cheers
  5. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,461
    199
    Looks spot on with the votex kit - identical to mine other than it being a saloon! As others have said, make sure you get the oil strainer seen to.
  6. dplovin
    dplovin Member
    416
    cheers mate been after one with this kit for a while now.
    this oil pickup pipe issue, is it a diy job or would i have to see a local garage
  7. Depends how high you rate your mechanical skills mate its a sump off job, would be perfect if you had access to a ramp but its doable on the ground jacked up and on stands
  8. dplovin
    dplovin Member
    416
    Probably best to get the garage to double check mate sounds abit ova pain. Any signs I should look out for in the meantime
