New A3 owner
chipmunk82
Hi all,
Just bought myself a 2.0fsi 53 plate A3 but having a few issues. Mainly the rev counter only works when it wants to.
Scanned it with trial version of VCDS and got these codes
8 Faults Found:
18322 - Pressure Sensor for Brake Boost (G294): Implausible Signal
P1914 - 008 - Implausible Signal - Intermittent
17439 - Shareware Version. To Decode all DTCs
P1031 - 004 - Please Register/Activate - Intermittent
18058 - Shareware Version. To Decode all DTCs
P1650 - 008 - Please Register/Activate - Intermittent
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 008 - Implausible Signal - Intermittent
17978 - Shareware Version. To Decode all DTCs
P1570 - 008 - Please Register/Activate - Intermittent
16455 - Shareware Version. To Decode all DTCs
P0071 - 002 - Please Register/Activate - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - Upper Limit Exceeded - Intermittent
16686 - Shareware Version. To Decode all DTCs
P0302 - 001 - Please Register/Activate - Intermittent
IF I've done my homework right these are:
18322 pressure sensor for brake boost implausible signal.
17439 intake manifold tuning valve, set point not reached
18058 powertrain data bus, missing message from instrument cluster
17978 engine start blocked by immobiliser
16455 Outside temperature sensor (G17) implausible signal
16684 random cylinder misfire
16686 random cylinder misfire
I cleared the codes 3 days ago as didn't know how long they had been there and so far none have come back from the engine section but either my car won't read or the trial won't read the other sections like ABS or Instruments.
The coils are a relatively simple fix (hopefully that's all it is) but the rpm counter is quite distracting! the speedo works, so does the temp (the fuel guage might be broken as it goes down far too quick!) but I think it's just the rpm counter at fault.
Also the ESP light doesn't come on at all, at start up or when the button is pressed. I hoping it's just the bulb but any hesitance or misfires I've put down to the coils as it normally happens in 4th or 5th at low revs but did happen once in second gear and it kangaroo'd a bit briefly......
Hope someone can offer some kind of advice, thanks in advance
Get scanned with a genuine hex-can-usb vcds system, as lite isn't designed for the 8P at all & its no use if you cant scan fully/properly.
Ok, I'll try and get it scanned fully at the weekend.
In the middle of the instrument cluster the only light that appears is when a door is open etc, when driving there's no trip computer with things like mpg or miles left in the tank etc, is this not standard or is mine not working? The clock works on the revs, and the mileage on the speedo but nothing in the middle part
Ok ignore last message, have searched and found mine doesnt have the buttons but I could retrofit a stalk and enable it with vcds?
Tried to scan on the full version but it only reads the engine section. All the others say no response from controller?
edit: his is the paid version of lite, but I'm guessing as its still lite it won't work anyway :(
Canbus car, needs better cable.
385
437
15
583
705
