Hi,
New to this forum so 'hi'. I've just bought a 57 plate 8P2 Sportback 2.0TDI (140 PS) from a friend (at a good price) as he is selling up to build an extension, and I needed a bigger car than my 2-seater MR2 to take my new-born baby around in. Very much enjoying the TDI torque so far.
The car is in pretty good condition but there are a couple of little (I think) issues that I want to resolve and a query or two:
1. FAULT CODES - Firstly a bit of advice. I've been reading about VCDS and I'm half tempted just to put my hand in my pocket to get a new RossTech cable (I'm considering some mapping/coding in the future anyway). However in the meantime I have a normal OBD2 reader, will this get access to all the error codes/reset, or do some of them specifically only show via full VAG-COM software? In my MR2 I've used this hardware and the DashCommand app to good effect so hoping it'll be the same on this car to diagnose problems?
2. DRIVERS DOOR LOCK - The drivers door lock is temperamental when used on the fob. It maybe takes 4-5 goes to get it to unlock (by locking and unlocking it a few times). I've had a read around and it seems this is a fairly common problem, however the resolution to it seems to vary. Some of the threads I've read suggest a new door catch unit is needed (£140 ish new), some just a failed solenoid (much cheaper). Is there any way I can test this to work out which I need? It only does it on the fob on that door, and is absolutely fine on the key. Will this throw specific fault codes that I will be able to read to identify the error and therefore the part I need?
3. ABS/ESP LIGHTS COMING ON - Again this seems to be fairly common. I've got the ABS and ESP lights coming on intermittently (I need to full test it but I think it's under hard-ish acceleration and cornering, definitely not braking) but when I switch the engine off and on again it all resets fine. From what I've read it seems like this might be an acceleration sensor? Again, I'm assuming some fault code may point me in the right direction to identify this so I can pin down the part I need?
4. TYRE ROTATION - The rears on this car are looking pretty new, however the fronts only have a couple of mm left on them. How quick do the tyres wear front/rear on these cars? On my MR2 the rears wear at almost exactly 2:1 compared to the fronts (i.e. you replace all four, then just the fronts, then all four, etc...). As on this car the tyres can be rotated front to back I was considering swapping them round to even up the wear but wasn't sure if I'd end up just needing to buy some new rears almost straight away anyway (in which case I'll just do them now and leave them on the front). Does that make sense? Hopefully.
5. BOSE SOUND SYSTEM - Is there an easy way to tell if this is installed on the car on not? The build sticker seems to imply it has (if I've read the code right) but it doesn't sound like it's particularly upgraded listening to it on the way to work this morning.
6. IPHONE/AUX CONNECTION - The car has a (I think) Concert 2+ double-din head unit in, however there is no connection in the glove box. Am I right in thinking a Connects2 box will allow me to set this up on the CD Changer setting with my iPhone? I'm just weighing it up as I'm half considering an basic I.C.E. install in which case I'd probably go for a compatible DAB head unit anyway, but I'm looking at the options.
Advice gratefully received. I have a little experience spattering my MR2 so plan to try and get these all resolved myself if I can to save on garage fees.
Thanks,
Andy
Thanks,
Andy
