New 3.2 DSG owner
mikeav6 Jun 13, 2010
  1. mikeav6
    mikeav6 New Member
    21
    Hi all
    Thought i'd take the oppotunity to introduce myself and mention a couple of potential issues with my new car. Overall, the car is fantastic, fast, smooth and refined. I only got the car on Friday night but I'm going to speak to the garage on Monday regarding the below:
    1.) Hesitation/surging between 1800-2000 rpm. From reading around, I expect it needs the software update from Audi
    2.) Jerky when setting off. Its almost impossible to set off smoothly, its almost like the car 'drops' the clutch. I have to be incredibly gentle with the throttle to get it to move off smoothly.
    3.) Squeeling noise from what sounds like auxilliary/fan belt down drivers side of the engine. Its intermittent, like every few seconds. May just need lubricating or something?
    Must say though, I still love it. Couple of pics:
    Regards
    Mike
  2. edition
    edition Active Member
    1,426
    Welcome :)
    Car's looking good!
    Yes the Update should get rid of that hesitation.
  3. S3 BUH
    S3 BUH Member
    355
    lovely looking motor mikeav6 glad to see the small problem havent put you off the car :icon_thumright:
  4. AFN1980
    AFN1980 Active Member
    162
    Nice car there mate, welcome to the 3.2 club. Lovely cars.
    Get the update from Audi. I had mine done about a month ago. Made all the difference and car is so nice to drive.
  5. lincoln_dj
    lincoln_dj Active Member VCDS Map User
    471
    61
    i'm getting the update soon too.
    as for issue 2 - think you just get used to that. i'd sometimes set off quite jerky, and also gear change from 1-2 sometimes 2-3 and it was just down to the way i'd got used to driving my previous car. i used to take foot off gas, then press in clutch. now with the 3.2 i kind of hold the throttle steady whilst dipping cutch and it is a lot smoother. just be careful to not slip the clutch when bringing foot back off clutch in next gear! (should have releases throttle slightly by time you do)
  6. suthsy
    suthsy New Member
    23
    Hello,
    Nice car mate,
    Do Audi update it free of charge?
  7. clem2192
    clem2192 Member
    174
    Nope you will have to pay the labour charges incurred for the time taken installing the update and that's if you're lucky. Loads of Audi dealers seem insistant on charging for an initial diagnostic check.
    Am planning on booking mine in for the end of this month, can somebody please let me know which software version I should be running after the update?
    Cheers!
  8. lincoln_dj
    471
    61
    Engines:
    starting from 8/2003 BDB - version 8087 (manual), version 8088 (DSG)
    starting from 9/2004 BMJ - version 8035 (manual), version 8036 (DSG)
    starting from 11/2005 BOY (only the first variants)
    check this http://www.audi-sport.net/vb/showthread.php?78089-Help-needed!..3.2Q-DSG-Hesitant-engine-2k-rpm/page13 for info
    from thread -
    What do I say to the dealer?
    You heard that AUDI a software update makes available for the VR6 3.2-Liter-Motoren, which the Motorruckeln, vibrating, jerky no-load operation and power loss are to repair.
    What, if it does not know or finds the update?
    Give it the TPL procedure number: 2005748/4
    Internal message code 8P01A005 or the updates CD No. 4F0 906,961 N is needed
  9. paddy
    paddy Audi=No fault code, no idea Team Ibis Audi S3 Black Edition DSG
    5,237
    153
    You will need to give them the TPL No. or they will not find the update on the available list from Audi GB.
  10. Sarah's A3
    Sarah's A3 MODERATOR V6 S3 Hybrid Staff Member Moderator
    5,920
    30
    TPL Procedure No 2005748/4
    Int Message Code 8P01A005
    Update CD 4F0906961N
    Nice car by the way and a good choice if I may say so myself!!
  11. mikeav6
    mikeav6 New Member
    21
    Hi everyone and thanks for the kind comments. Thanks for all the codes above which should make getting it sorted a bit easier. Spoke with the garage today and they were aware of the hesitation on the car so bit dissapointed that they did 't sort it pre-sale. Then again, it's all about money I suppose.
    Hopefully will get the bits sorted then got a trip to the lakes planned in july and then down to south of France in august. Can't wait!
  12. mikeav6
    mikeav6 New Member
    21
    Hi. I went to my local Audi garage, gave them the TPL number etc. They took my registration and said that that update wasn't available for my car. They said there is an update available which is supposed to cure hesitation above 5k but I don't have that problem. The Evans Halshaw that I bought the car from are sending it to Audi to get the hesitation and gearbox looked at. I will give them the TPL number again and tell them that it may not show as an available update but that it is what it needs and that it should be on software version 8036 when they have finished.
  13. -Ju-
    -Ju- Well-Known Member Team Panther VCDS Map User Audi S3
    2,336
    462
    Hi Mike, I originally found the update on a german website after spending 10 months looking for the cure. Numerous independants and main dealers looked at the problem but couldn't sort it out.
    Audi will tell you EVERY time that your car has the latest software on because the computer tells them that, the only way to approach it is to give them all the relevant info and hope that they are willing to play ball
    Unfortunately until Audi UK accept that there is a problem and put the update on general release then it's hit and miss getting it done at the moment I'm afraid.
    Keep with it though and you will get it sorted.
    BTW welcome to the 3.2 club:cool:
  14. edition
    1,426
    Julian that isn't stictly the case.... When they plugged my new ecu in and plugged it in on there computer it listed the new update.
    I'm guessing that they dont even bother...
  15. Sarah's A3
    5,920
    30
    I'm still waiting to hear from my local Audi. She took all the details so hopefully..........
  16. -Ju-
    2,336
    462
    That's interesting then. It shows as a valid update for your new ECU on a manual car even though it came with old software preloaded, but DSG's don't, just shows how ridiculous the situation is.
  17. edition
    1,426
    Hehe yeh came with old software on it but showed the update when plugged into there machine!
  18. mikeav6
    mikeav6 New Member
    21
    I'll make sure the update gets done if I have to go and camp out in Audi Service reception because I can't be on with this hesitation nonsense. I've started driving it in manual mode around town to stay above 2k rpm.
    Will keep you updated on how I get on. Car goes in on 6th July.
  19. Hunty
    Hunty Member
    172
    Welcome along Mike. Can be a jumpy little bugger! Definately the right choice. Good luck with the update
  20. mikeav6
    mikeav6 New Member
    21
    Hi all. Just an update on the above. I had the update done and I must say the car is much much better. Really smooth drive and sounds much healthier. Definitely worth it if you have the hesitation issue.
    I am disappointed though that they haven't sorted my squeaking engine. They claimed they couldn't hear it. I took it round the block after collection and took it straight back to them as it is blatently obvious. The Evans Halshaw guy asked me to take it back down to Audi for their technician to have a listen. He says it could be a tensioner, the alternator, power steering pump, or the water pump. He needs to get it up onto the ramps and take under tray off to track it down. As a result I took it back to Evans Halshaw and left it there again. Downside is that they only have **** Citreon C2's as courtesy cars. Bit of a step down!
    Might get to drive this car at some point!
  21. Sarah's A3
    5,920
    30
    Hey glad you got the hesitation sorted! Better isnt it! Mines just needed the coils renewing but wow even better again!
    Sure you will get to the bottom of the squeaking engine, cant be too much surely! Good luck..
  22. mikeav6
    mikeav6 New Member
    21
    Thanks Sarah. Well I'm just glad its under warranty and credit to Evans Halshaw, they haven't argued any step of the way they have just happily sent the car to Audi and paid them so I'm sure it will get sorted!
    Car is so much better to drive though, just get rid of that squeak and we're sorted. Can start saving for my Remus/Milltek then!
  23. Sarah's A3
    5,920
    30
    yeh and all of the rest! It never stops! One mod leads onto the next on here lol
    Enjoy the car though, it certainly makes you smile
