  1. Bad Sir Culation
    Bad Sir Culation Member
    287
    17
    Put the replacement headlights in, one sidelight bulb is dead, the other is doing a Morse Code impersonation.
    One of the dipped beam Xenons also didn't come on initially on one switch on of the lights. Fed up today.
    Halfords it is tonight then...
  2. Gops
    3,198
    666
    Did you do a facelift conversion?
  3. Bad Sir Culation
    287
    17
    It already has one. The lights it had didn't have back covers and the wiring was butchered.
    I've put it as close to a standard setup as I possibly could now. One of the HID ballasts has the full loom with it, the other doesn't and so I had to make a loom for the headlight wires to the ballast. Real ball ache.
  4. Sean_S3
    Sean_S3 Member
    323
    17
    What are you needing , some D2S bulbs and some side light 501 bulbs ?
  5. Bad Sir Culation
    287
    17
    I'm good now. Picked up some 501 led's so off to try them.
  6. Sean_S3
    Sean_S3 Member
    323
    17
    No probs . Is the car running better with the new stat ?
  7. Bad Sir Culation
    287
    17
    Not actually been able to take it out since changing it! It's still struggling sometimes when starting though and cutting out so not sure what's responsible for that.... Hope fuel pump is OK!
    I feel totally broken tonight. Should have been back on the road today and I am being held back by these lights. Took the flashing bulb out and swapped in a new LED. I now have no sidelight at either side. Swapped the other bulb too. No change.
    I tested the main headlight connector and two pins are showing just under 14v with the car running, the two remaining pins show 0.09v and 0.03v. I don't know what they actually should be?
  8. Bad Sir Culation
    287
    17
    Actually, is it possible that the car doesn't like these led's somehow? I did also buy some regular 501 bulbs that I can try if need be, just didn't want to open them up and make them non returnable if possible.
  9. Sean_S3
    Sean_S3 Member
    323
    17
    I may have some standard 501 bulbs lying about , I'll check tomorrow.
  10. JimS3
    JimS3 Active Member
    736
    72
    Expect you have already tried this, but have you rotated the LEDs 180 degrees in the bulb holders? being diodes they only pass current in on direction.
  11. kwistof
    kwistof South East Events Moderator Regional Rep
    2,434
    535
    1 of my LED bulbs didn't work due to this.
    Quick 180 degree flip and it was sorted- hope yours is as easy OP
  12. s33nyboy12
    s33nyboy12 Well-Known Member Team Ibis Team V8 Audi R8 s tronic
    1,488
    203
    Don't give up mate! You will get there in the end...........:)
    Sean
  13. Bad Sir Culation
    287
    17
    I think I tried but didn't make a difference. I will double check by doing it again this morning.
    I don't need any of those fancy canbus compatible LED's for this car do I? These are just regular LED bulbs.
  14. JimS3
    JimS3 Active Member
    736
    72
    Just standard ones. The side lights are not connected to the bulb check module so no resistor needed.
  15. Nick101
    Nick101 Boost fiend
    211
    15
    No, they aren't canbus. I put 501 LEDs on my car the other week after facelift conversion, and had no flickering.
    I have had a problem with passenger side headlamp not coming on first attempt, I took out the battery and battery tray yesterday and cleaned/greased all earths under there, and the positive lead going from battery to starter.
    Slow start and headlamp issues all sorted now! Worth a try mate.
  16. Bad Sir Culation
    287
    17
    Cheers mate.
    There are earths under there?
  17. Bad Sir Culation
    287
    17
    Well I've fixed the lights! At least I think I have. Have to see if that dipped beam gives me anymore trouble going forward.
    All these difficult DIY jobs have really come good now, as they have allowed me to gain the experience I needed to find the root cause of the sidelight issue.
    The bulbs were indeed in the wrong way.....
    Sean_S3, JimS3 and kwistof like this.
  18. Nick101
    Nick101 Boost fiend
    211
    15
    Yea there are 2 earthing points under the battery tray, with 2 on each point.
    Worth doing as bad earths can cause all sorts of strange problems.
    At least the sidelights are working now!
  19. Bad Sir Culation
    287
    17
    I currently have a problem with something constantly draining the battery. I'll look at these next. Cheers for that.
  20. kwistof
    2,434
    535
    Cheap quick and easy fix then - result :arco:
  21. Bad Sir Culation
    287
    17
    Yup, just feel ridiculous haha!
