Nervous breakdown time.. cement splashes
larry1 Jun 23, 2007
  1. larry1
    larry1 New Member
    24
    My 2003 BLACK A4 AVANT got splashed with cement somewhere during the week. Cement splashes everywhere! I didnt get the chance to clean at the time. spent 2 hours scratching it off today as carefully as possible but my paintwork is fcuked.. can't believe it. Tried some T cut but it only took the edge of the scratches. Please tell me I dont re a respray job.. help me please
  2. a4quat
    a4quat Member
    374
    i deliver concrete for a living, what i use on my mixer truck is hydrochloric acid which pulls it off straight away but it makes the paintwork really dull after many uses. NEVER scratch it off!
  3. auditek
    auditek Member
    286
    fukt .........paintjob. my van got splatted last year, thought it would knock off. similiar to a leach. nah nah took the paint with it...... so i smashed windows on jcb at weekend, monday it got fixed, did it again following weekend, wankers !
  4. ManicMunky
    ManicMunky Member
    311
    find the builders, and sort it out
  5. d3fy
    d3fy Active Member
    1,412
  6. larry1
    larry1 New Member
    24
    Not an option.. no idea where it happened.
    Regarding the scratches .. any good solutions?
  7. ManicMunky
    ManicMunky Member
    311
    can you not retrace your steps? figure out where you've been?
  8. larry1
    larry1 New Member
    24
    No point now. too late & how could I prove it
  9. Defratos
    Defratos YouÂ’re Dethpicable!!
    2,232
    I had a similar problem mate, so I feel for you. I was following a cement truck a bit too close and got a few splashes on, clean it off as best as I could but have 3 very fine scratch marks, hope you find a (cheap) solution soon.
  10. 205man
    205man Active Member
    1,071
    13
    you can soak the splashes with hot water/shampoo, and keep soaking them, not letting them dry, the cement will go softer and can can be removed by very gentle rubbing, it may still leave some faint mark but they can be polished out
    the other way is to us a jet wash, preferably one with an oscilatting spray and start with jet away from the car slowly moving in until they lift and so not risking paint to much, again then just polish
  11. JamS3
    JamS3 Active Member
    2,258
    20
    Coca Cola contains phosphoric acid which when applied to cement will break it down and make it easier for it to come off, just wash the coke off fully when the cement is off.
    This works on clothes also!
  12. DiscoPanda
    DiscoPanda Member
    159
    Small amounts of cement (now turned to concrete) will dry up and I imagine will fall off over time with some help from some of the methods mentioned.
    Is it noticeable? If not I'd be inclined to leave it alone as removing it could make it worse.
  13. atc
    atc Member
    105
    If it were me I'd take the car to a good trusted preferably recomended paint shop (don't panic, not for a respray) and ask them for advice. They have all kinds of clever paint finishers and tools, much better than T-Cut so they should be able to help. It may cost 60-100 to have them buff the car up but it'll be worth it! You could try stuff like rubbing compound or various grades of G fluid but your more likely to do harm than good, a paint finisher will know how far he can go with the laquer before its knackered. I guess worts case would be to have the car re-laqured cheaper than a respray!
  14. mwstewart
    mwstewart Member
    199
    I use 1500 grit for the bad scratches, 2000 grit to finish then a cutting compound and buffer followed by a polish.
