needs some help
HuntsA4 Dec 26, 2005
  1. HuntsA4
    HuntsA4 Member
    91
    You've probably read my other posts regarding problems getting a new steering rack fitted under warranty.
    Well still have problems, xmas eve it started creaking like a barn door when i go from full lock to full lock, it doesn't do it everytime. but when it does its very loud. Its so bad I dare not drive it. tried working steering from lock to lock a few times in case of air locks or stiffness, but no help.
    Any ideas? I know i shouldn't let it stress me so much, but with everything else thats happened this is the last straw.
  2. HuntsA4
    HuntsA4 Member
    91
    should say this is after the new rack being fitted, so it shouldn't be the rack? although thats where the noise appears to be coming from
  3. scoTTy
    scoTTy Active Member
    1,962
    I'm puzzzled. If it was fitted under warranty then just take the car back.
  4. HuntsA4
    HuntsA4 Member
    91
    I see what your saying, but as its intermittent I suspect I'll be sent away they can't replicate the fault, this happened twice when I had the original problem
  5. kenny_boon
    kenny_boon Active Member
    466
    71
    my steering on my s-line does this sometimes when its wet, dealer cant find a problem /ubbthreads/images/graemlins/frown.gif
  6. HuntsA4
    HuntsA4 Member
    91
    thats interesting Kenny, I'm going to hit the dealer as they open in the morning, I'll post their response.
    I wonder why yours would do it only in the wet? you would think less friction would stop it not cause it?
  7. kenny_boon
    466
    71
    it sounds a bit like one of the rubber boots catching on something on my car
  8. HuntsA4
    HuntsA4 Member
    91
    Well for a change reasonably impressed with dealer today.
    Took it in first thing and was given a courtesy car, and luckily managed to reproduce the fault for the Service manager. He was horrified.
    Called me back this afternoon to say that the Steering rack fitted had a fault which has since been modified to resolve,but this rack was in their stock and to the old spec. new rack arrives and hopefully fitted tomorrow.
    Lets hope this is the end of it.
  9. HuntsA4
    HuntsA4 Member
    91
    2nd rack didn't work!
    Audi technical have now suggested changing the Steering fluid pipes and resevoir with modified ones?? who knows
  10. HuntsA4
    HuntsA4 Member
    91
    The new pipes and Resevoir have worked!! apparently the mod stops the fluid cavitating ( I think thats how its spelt) this apparently means a build up of air in the fluid which makes a noise similar to air in your domestic central heating.
    Don't really care about how they did it, but they have!!
    Could this also be the solution to the creaking problems on the A3 rack??
  11. Nelson_R32
    Nelson_R32 Member
    305
    No, its not. The A3 is a totally different setup. The A3 racks have an expected delivery date of Late January.
    Some B7's (mine included) are still suffering from groaning problems. The solution is to fit a modified Reservior bottle with a different restrictor in. Mines being sorted on Wednesday so I'll let you know how it goes.
