So here goes...............
having had it running lumpy (i thought misfire) on idle for a while now (but runs smooth as once under way) I have been trying to get to the bottom of it. Here is what I have found. I sent it into a diesel diagnostics, pump & injection centre (who are well recommended near me), & they have said:
Tested all injectors & they are fine (disappointing as cheap to fix)
Compression test on engine & all cylinders are fine
Visible inspection of cams & minor wear but not anyhing you wouldn't expect & that shouldn't cause an issue (2nd garage to have said that)
They have said they think its likely to do with a worn dual mass flywheel causing vibration when its idling & that disappears once its moving faster. They reckon they have seen this in other vehicles where diagnostics shows nothing wrong with the injection and engine & is that. Penny for your thoughts & opinions as to whether this could be the issue?
I would quite like it to be - as new clutch & flywheel = an area that i know is weak on the car - a bit of a gritty pull away (I've been thinking its going) & high clutch pedal, also recently a couple of snatched gear changes coming down to 3rd.. this could also tally with a previous problem, where it wouldn't go into gear & i had to call out RAC - RAC said clutch, Mr Clutch said gearbox - but having drained oil & replaced it went into gear & ran fine again (apart from lumpy idle). I've been running it for probably 4 months since.
So. any opinions before i go all in for a new clutch & dual mass? (£995 with Mr Clutch)
