Needle sweep
Soft lad Nov 18, 2012
  1. Soft lad
    Soft lad Member
    148
    I recently borrowed an A5 that had the needle sweep but after asking my pathetic dealer who told me 2 other things were not possible, they said my model doesn't do it or can't be told to. Anyone know why Audi can't do it?
  2. Gizmo68
    Gizmo68 VCDS owner in Kent VCDS Map User
    88
    How old is the car?
    Does it have the red or white DIS? I believe (certainly true of every car I have activated it… or tried to) that the car needs the white DIS.
  3. a6_chris
    a6_chris Well-Known Member
    1,883
    159
    All b8 a4s can have the needle sweep enabled regardless of age
    Audi won't do it as its not considered an official retrofit or not approved by Germany or something.
  4. AshA4
    AshA4 Ash
    285
    What is needle sweep?
    Test of dash needles, as in speedo etc?
  5. a6_chris
    1,883
    159
    When you turn the ignition on the dials sweep from start to finish once.
    YouTube search - Audi a4 needle sweep
  6. Gizmo68
    88
  7. Bigslope
    Bigslope Member
    44
    use vcds (Vagcom) and go to instruments, then long coding helper and tick needle sweep. Easy as that.
    If you don't have it look around the site for someone near you who would do it either free or for a nominal fee.
  8. Gizmo68
    88
    I do it from ‘Adaptations’ under “Staging”.
  9. Soft lad
    Soft lad Member
    148
    Gizmo, it's a 62. When you say red or white, are you referring to like the radio station names etc? Mines mostly yellow.
  10. Gizmo68
    88
    Ah a 62 will have the feature, I was referring to the DIS in the instrument panel (between the speedo and rev counter) from around 2009 they are all white.
    Whereabouts are you? Someone with VCDS can enable this in a few mins.
  11. Audi Dynamik
    Audi Dynamik Well-Known Member
    2,218
    308
    How do the vagcoms work ? Do plug them into your laptop ?
  12. a6_chris
    1,883
    159
  13. NHN
    29,284
    1,695
    As a genuine seller & advertiser of this forum, give me a shout if you are interested in purchasing vcds :)
  14. Audi Dynamik
    2,218
    308
    Will do NHN ;)
    Slightly :sign_ot: here anyway :unsure:
