Needle Sweep feature on MY07 S3s...
Rabbit222 Aug 23, 2007
  1. Rabbit222
    Rabbit222 Active Member
    708
    124
    43
    I dropped by a local Audi dealer yesterday to have a look at a MY08 S3 that had just arrived. It had the Needle Sweep feature enabled...we hooked up the VAS to my car to see what the differences are between the MY08 and MY07 spec. Turns out the Cluster would need to be changed inorder to have this feature active on all MY07 spec cars, not even an ECU upgrade will do...
    Thought I'd let you guys know.
  2. thebears
    thebears Member
    90
    That sorts that one then. Any other differecnes between the two?
  3. Rabbit222
    708
    124
    43
    Apart from the cluster,no other differences.
  4. jojje
    jojje New Member
    15
    Is there any visual difference between 07 and 08 cluster? Or any other difference for that matter? Is the needle sweep the only thing added to my08?
  5. Rabbit222
    708
    124
    43
    Cosmetically, no. The cluster looks identical and so does everything else on the car. We checked the VIN numbers on the MY08 as well as the MY07 car and found the clusters to be different part numbers. I can only assume that the needle sweep feature is built into the MY08 cluster. It has an additional feature in the DIS menu, Indications. Once you access that menu you can switch the dials on or off.
  6. thebears
    thebears Member
    90
    dashpod failure anyone :nyah:
  7. Covenant
    Covenant Member
    246
    Heh - you'd probably have to wait until the part bins are empty for the old version - they usually have a few left even once they start fitting the new MY version.
  8. TheWusMan
    TheWusMan Member
    60
    I think my instrument cluster back-chatted me this morning.
    I hate bad attitude in a cluster - I'm going to go give it a solid thumping and call the dealer and tell him it's dead - put an order in for a MY08 one please.
    Problem sorted.:icon_thumright:
  9. Rabbit222
    708
    124
    43
    LOL! Goodluck Sven, I just queried from the Parts bin guys...MY08 cluster is around R11k:scared2:
  10. JohnS3
    JohnS3 Active Member
    3,032
    Well that's that one sorted out then!
  11. JohnS3
    3,032
    So thats £764, ouch.......
  12. klauster
    klauster Well-Known Member
    1,188
    112
    it would have been nice to have, but its not worth the hassle...
  13. Rabbit222
    708
    124
    43
    Here is the part number for those interested,
    8P0 920 931 GX
  14. treblesykes
    treblesykes Member
    690
    what the heck is a Needle Sweep feature? Does the car clean up after the xmas tree every year?
  15. JohnS3
    3,032
    No, it does this....
    [ytv]TfC24YQOcsE[/ytv]
  16. treblesykes
    treblesykes Member
    690
    looks bad, it might stop all that nonsense if you tighten the connections at the back
  17. Covenant
    Covenant Member
    246
    Now - if it was like this baby - I might even consider it...
  18. JohnS3
    3,032
    Dodgy link, try this one. Now I want one!!
    [ytv]1Wnu7OFZ0hQ[/ytv]
  19. phantom
    phantom On Boost
    1,750
    Is that a after market cluster light mod?
    p
  20. N8
    17,163
    718
    good question, can u do this via vag com
  21. JohnS3
    3,032
  22. Spin140
    Spin140 Well-Known Member
    2,196
    186
    at least the dealer was telling the truth for once, I asked about this update when I was last in and they said "not possible on your model".
    To be fair it looks cool but you're not really going to miss it, thanks for the info though .
  23. Kontraband
    Kontraband Active Member
    2,001
    what does MY actually stand for??
  24. markwiggy
    markwiggy Third Gear
    1,132
    94
    Model Year !!
    Mark
  25. phantom
    phantom On Boost
    1,750
    Mine does this sweep, but ive got a 07 car?
    p
  26. Kontraband
    2,001
    ah... I was thinking it was Manufacture year... but model year... yeah, cool. Cheers. :icon_thumright:
  27. N8
    17,163
    718
    So how do you get needle sweep? Is there a retro fit?
  28. markwiggy
    1,132
    94
    Buy a MY08 S3, you may be able to retrofit but i think you need to change the instrument cluster among other things. Is it worth it, I don't think so !! Have I got it on mine ? No !! Am I bovvered ? No !!
    Think I am correct in saying it is exclusive on the S3, sure i will be corrected if wrong.
    Mark
  29. julians
    julians Member
    312
    I think all the S and RS (inc R8) do it now.
  30. phantom
    phantom On Boost
    1,750
    Do you know why i would have it then?
    My car is deffo 07 , just over 6 month old?
    p
  31. julians
    julians Member
    312
    I think the MY08 cars started being delivered to dealers about from about mid 07. My car was delivered in Oct 07 and also has the needle sweep.
  32. N8
    17,163
    718
    Ok then! I'll leave it.
