Need Vag com set up help, Tech help maybe? NHN?
LeeT Jun 29, 2011
  1. LeeT
    LeeT Member
    429
    Right after a recent discussion on here i have bought an ebay vag com lead. When installing/setting up i get as far as selecting the device manager, right clicking usb>serial and bring up the properties. But, heres my problem, when i click on the advanced tab to try and select a COM port between 1 and 4, it says "you must have write priveleges in the registry for this device in order to modify the device advanced settings????? Someone please help, im not too clued up on PC'S
  2. LeeT
    LeeT Member
    429
    Right, i now have that sorted out! Next problem, everything i try to scan it either says controller not found or professional grade cable needed?
    Can anyone help with this?
  3. Bradderz_1988
    3,988
    261
    I'd say that means the lead isn't working at all as in it isn't communicating with the ecu's and the one you have may not be the correct lead/pin layout !
  4. aragorn
    18,612
    872
    I'm sure NHN will be delighted to inform you that these are the exact problems people face when using copy leads and as such you should spend 20x the amount on a genuine one.
    You need to supply more information.
    Which com port have you selected, and does it "stick" on that port after a reboot?
    Have you selected the appropriate matching com port in the vagcom settings?
    Which version of the software are you using?
    Does the blue light on the interface light up when connected to the car?
    Do you have the ignition on while trying to connect?
  5. NHN
    29,577
    1,779
    No need, you did it for me, just hope you dont expect any commission :lmfao:
  6. LeeT
    LeeT Member
    429
    Ive selected COM1 and the test shows that the interface has been found and it still remains at COM1 after a reboot
    Im using 409.1, i think thats what you mean?
    Yes the blue light does come on when connected to car.
    Yes i do have the ignition on
  7. LeeT
    LeeT Member
    429
    Right, when i plug into the car and do the test com port. It says that errors are detected and results will be unreliable. I get a screen pop up saying
    Port status, OK
    Interface found
    Type, serial pass through
    opto/iso: No
    ross tech design, No
    Latency test poor
    7.0 11.0 13.6 (ms)
    Can anyone shed some light on this?
  8. aragorn
    18,612
    872
    If you go back into the advanced settings for the com port (where you set it to com1), you can adjust the latency timer, try 4ms or 1ms and see if that improves things.
    Do you hear the dashboard clicking when you connect to the engine controller?
  9. LeeT
    LeeT Member
    429
    everytime i try and connect it says controller not found so no i havent heard any clicking. Thanks for the help so far
  10. Jules
    Jules Member
    130
    have you tried right clicking on vagcom and run as administrator thats what i have to do on my win7 laptop?
  11. LeeT
    LeeT Member
    429
    Do i click right click on the desktop short cut? Ill give anything a go as i need to resolve some problems asap
  12. LeeT
    LeeT Member
    429
    Still no joy with this :( I desperately need to get these fault codes read and cleared. Ive tried the administrator mode with no joy as well. Whos the whizz kid who can get this working for me then?
  13. griswold
    griswold Member
    353
    You say your using 409.1 dit it come with the cable?
    it may be corrupt
    Download vcds lite and try that and change the latency to 1
  14. LeeT
    LeeT Member
    429
    Hello there, i bought it from ebay so was a cable with cd. I have downloaded VCD lite from ross tech and changed the latency to 1 but still no joy although Latency is now either fair or good when i test. It is still saying no response from controller
  15. aragorn
    18,612
    872
    Is it just one controller that doesnt work?
    IE if your trying to open ABS and it keeps failing, try opening instruments or engine instead?
  16. LeeT
    LeeT Member
    429
    i have tried both airbags and ABS which are the ones i need access to and both controllers say no response
  17. aragorn
    18,612
    872
    Well given your trying to access something thats broken, it may be broken in a way that stops vagcom talking to it.
    Try instruments or engine as those should work, which will let you know if the lead is actually functioning!
  18. LeeT
    LeeT Member
    429
    nope, ive tried a few different ones and they all say no response from controller still :(
    I have tried it on my other laptop too but still no response from controllers. I can hear clicking from the dash though so its trying to do something
