Need to change the injector harness on my tdi, anyone done it before?
5am
Lannnndaaaaan
I need to change the injector harness on my car. Anyone done it before on a tdi?
Anything i need to be aware of or is it quite straight forward? Id there a 'HOW TO' anywhere?
Thanks.
Very easy to do mate
1, remove rocker cover
2, disconnect each injector plug
3, undo the 10mm nut/bolt on the end of the head that holds the loom plug
4, compress the 2 metal spring clips that hold the loom in the head
5, slide loom out
6 slide new loom in, connect injectors and refit in reverse order
Excellent. Thanks :thumbsup:
So no special tools needed?
None what so ever :), although if you have long nose pliers that will help you disconnect the injector multiplug :)
Good stuff.
After changing the loom will there be a fault code appearing?
Shouldnt be from changing the loom, although you will prob have a stored code of the injector thats causing the misfire, mk5 golfs do, unsure if the mk4 platform cars do tho
