Need some info regarding registration please
abdus Jul 31, 2008
  1. abdus
    abdus Top Gear VCDS Map User
    1,827
    I have a third party cable which I'm using. It has been working fine until now with a shareware version.
    Now I want to be fully registered.
    1. If I use the third party cable, will ALL the funtions of vagcom work when I'm registered?
    2. If later, I want to buy one of the cable from ross-tech, will I still be able to use the same registered software?
    3. Will I be able to update the software and still use the third party cable?
    4. what happens if ever the pc/laptop being used becomes faulty, will i be able to use the registered vagcom on another pc (installing again?)
  2. A4Ade
    A4Ade Active Member
    106
    1. All the functions of version 409 will work, but this is now quite an old version, and a good few functions have been added to the latest version which you will still not have.
    2. If you upgrade to a Ross-Tech cable, then you would not need to use the same software, since then you would be able to use their latest software and get the latest functions. I believe, however, that you would get is discount of the $99 registration fee off of the price of any upgrade you purchase.
    3. No, version 409 is the latest version which is compatible with 3rd party cables.
    4. You can only install your registered version of VagCom on 1 PC at a time. However, if your PC becomes faulty (or you change it etc.) then I believe you can unregister the software from one PC, and ask Ross-Tech to provide you with a new license for the new PC.
    I hope this helps - I think I am correct but you would be advised to check with Ross-Tech before parting with any cash....
    Ade
  3. abdus
    1,827
    thanks for the clarifications :)
    My car is an A3 year 2000. Will the new functions be needed for now?
  4. A4Ade
    A4Ade Active Member
    106
    I guess that depends on what you want to do :)
    I don't really know what the new version can do - I only have a registered copy of version 409. As far as reading / clearing faults, measuring blocks, adapting / coding control modules etc then as far as I'm aware you don't need the newer versions. Your main reason to upgrade would be if you bought a post-2004 CANBUS compatible car and could no longer use your existing interface. If you are interested in the additional features of the new software though, then I imagine you can find info on them on the Ross-Tech website.
    If you do register your software, perhaps you can let me know if you have any luck performing an auto-scan. I can auto-scan my A4 ok, but I tried auto-scanning my mate's 2001 S3 and it wouldn't work. Be interested to hear how it goes on a similar platform.
    Cheers,
    Ade
  5. abdus
    1,827
    That's teh shareware version I'm currently using- v 409
    Think I'll be registering very soon and I'll post results when done :)
  6. Sebastian
    Sebastian Member
    286
    Common difference between versions and between Fully Registered and Shareware.
    Shareware:
    Cannot do AutoScan
    Won't display text for all fault codes
    No Basic Settings (so no TBA, Xenon levelling, etc or checking timing on TDI's)
    No Adaptation Saving (so no changing of locking/lights/horn behavior)
    No Output Tests
    No Tech Support from Ross-Tech
    Limitations of 311 and 409 even if Fully Registered:
    No Generic OBD-II
    Won't work with CAN-Bus vehicles
    Fewer fault code definitions and label files
    No built-in Activation (you'll be limited to a single PC)
    No Advanced Measuring Blocks
    No Acceleration Measurement
    No Automatic Service Reminder Reset
    No Session Log Support
    No Dual ECU Support
    No Automatic Updates
    No Guided Readiness
    Does that answer your questions?
  7. abdus
    1,827
    Sebastien, thanks for your reply. I just sent you an email :)
