Need some help with a fault code please?
DaveA3-TDI Nov 8, 2011
  1. DaveA3-TDI
    DaveA3-TDI Member
    249
    Hello.
    My car comes up with the fault code below and I cannot clear it. It comes straight back! Can anyone point me in the right direction? The only thing that I can think of that is not working on my car is the passenger side door mirror glass which is supposed to dim to stop headlight reflection. Could that be anything to do with the error?
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Control Module Part Number: 1K0 907 530 K HW: 1K0 907 951
    Component and/or Version: J533__Gateway H12 0170
    Software Coding: 7F3F07C007002103
    Work Shop Code: WSC 06314 000 00000
    1 Fault Found:
    00470 - Combination comfort Databus in Single Wire
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 29
    Mileage: 146384 km
    Time Indication: 0
    Date: 2011.11.08
    Time: 18:56:08
    Any help is greatly appreciated.
    thanks
  2. Khufu
    Khufu Well-Known Member
    5,704
    31
    ross techs page:
    00470 - Ross-Tech Wiki
    You could try to disconect the power to the glass in case there is a short in it?
  3. DaveA3-TDI
    DaveA3-TDI Member
    249
    thanks, I had a quick look there but didn't make much sense to me lol. Is it easy to disconnect the power to the glass? What does the error mean, am I right in thinking that it is an issue with the canbus system? The system runs in a mirror mode with the signal being sent down 2 wires but at the moment mine is only working in single wire mode?
  4. mike foster
    3,967
    I have had this error code on my car for 12 months now and can't clear it but everything on the car works fine ! I think it is just what it says in that instead of using two wire communication it's just using one.
    I don't think the door mirror problem is related at all but I'm sorry, my car doesn't have that facility so I can't help with the problem !
  5. DaveA3-TDI
    DaveA3-TDI Member
    249
    What should I be checking?
  6. Tracebuzta
    Tracebuzta Member
    97
    Is the mirror heated?
  7. DaveA3-TDI
    DaveA3-TDI Member
    249
    Yes the mirror is heated?
  8. Khufu
    5,704
    31
    im wondering, assuming its canbus error & using single wire instead of hi/low, didnt somebody else have corrosion issues at the multiplug going into the CanGateway module in behind the glovebox?
  9. DaveA3-TDI
    DaveA3-TDI Member
    249
    Isn't there a way to narrow down the fault to something more useful?
  10. mike foster
    3,967
    Did the mirror dipping ever work ? Have you got auto wipers/lights ? Are they still working ?
  11. DaveA3-TDI
    DaveA3-TDI Member
    249
    Yes the mirror dipping has always worked until the other day. Yes I have auto wipers/lights and they are still working.
