Need some advice
shariain Jul 31, 2012
  1. shariain
    shariain Well-Known Member
    1,183
    192
    Just finished work and pulled up at a set of lights with a work mate and had a bit of a race from the lights then all of a sudden my ESP light flashes on an there is now some sort of rubbing/rattle/grinding/knocking noise when I am driving my 1st thoughts were I had burst a drive shaft on the rear but they look ok. Is it possible I could have sheared the prop shaft bolts as the noise also sounds like its coming from the front as well as the rear.
  2. shariain
    1,183
    192
    I have just jacked the car up on the rear passenger side and the wheel was moving about while it is bolted to the car took the wheel off and had a look and found the drive shaft floating about in the back of the hub.
    Now have I snapped my drive shaft or is my wheel bearing away or both.
    There was no noise to indicate that the wheel bearing was on its way out.
  3. shariain
    1,183
    192
    Just got word from the garage. My wheel bearing had failed causing my cv joint to break and the cv joint was banging about in the back of the hub and that damaged the bottom of the abs sensor.
    It never rains just pisses down.
  4. wuta3
    wuta3 Well-Known Member
    1,131
    347
    Yea but, did you win the race?
  5. shariain
    1,183
    192
    Up until my car broke I was a good car length ahead as soon as I heard the noise from the back end my back end went in to over drive. What have I done.
    Expensive fun
  6. wez3570
    wez3570 Member
    704
    20
    Have you been quoted a price?
  7. shariain
    1,183
    192
    £350 I got the car back yesterday morning garage showed me my old parts and what a mess they were in.
    Fitted a complete hub, new cv joint and a new abs sensor.
  8. OVRA3
    OVRA3 Well-Known Member
    1,079
    80
    What was your mate driving?
  9. shariain
    1,183
    192
    Leon Cupra r 225
