Need helps. Does drive shaft need to be refit by AUDI??
S3JET Sep 1, 2008
  1. S3JET
    S3JET Member
    79
    Ok, as the topic says. i fit my milltek exhaust turbo back.
    as to fit this exhaust the drive shaft need to be remove.
    after we fitting everything back on.the car drives fine, but only above 100km on the free way the car shakes aibt.
    do i need to ask Audi to refit the shaft or they just bolt back on. are there any adjustment need to be done when the shaft put it back on??
  2. NHN
    29,328
    1,708
    I would double check the shaft fitment fella, you should be able to do yourself
  3. Iggu
    Iggu Active Member
    1,229
  4. Khufu
    Khufu Well-Known Member
    5,704
    31
    I know drive shafts are often balanced so they need to be put back on by lining the holes so they all match up with how they came off. When I did it on my old BMW I marked the joint with tipex to ensure this. Could be same with S3
