im trying to code out the tire circumfrance varient. it says "coding rejected. error 22: conditions not correct or request sequence error"
process for tire circumference adjustment"
17 instrument
7 long coding helper
byte 3
bit 0-2
tire circumference varient
stock for me is "03 tire circumference varient 4"
this coding helps with speedometer adjustments when going larger or smaller diameter rims. without this, when you change out the rims or even when you get the car from the factory it could be little off, this will help get you back to where you need to be on your speedo.
17 instrument
byte 3
bit 0-2
