need help with my abs module
boost-addict Sep 20, 2013
  1. boost-addict
    boost-addict Well-Known Member
    1,000
    39
    right so when i bought the car (which i wish i didnt) it had a abs light on and was told its a abs sensor, so bought it and the rest of the car has only given me minor issues as normal, other then the clutch which is being sorted.
    so problem i have is i sent off my module but apparently never got there, and the recorded tracking showed no one signed!
    so i am now left and have been for the passed 6 months with no abs module. i did take note of the part number which is
    0 273 004 284 i have it saved as a saved search and the only ones that pop up are from usa. and new ones are WELL out of my budget. altho it may just have to be a new one!
    so can any one tell me what ones will fit and would i need full vcds or would a registered lite work. i dont have any coding obviously as the module would lock vcds out. so what can i do as mot is up in march and ive been looking and looking
    and i really need to get it sorted a. because winter is coming up and b. as itll fail the mot.
    i understand you cant disable the abs and have new brake lines routed to cut out the abs system. which i wouldn't want to do but they work with out fault any way
    basicly HELP!!!!
  2. PAULF
    PAULF Active Member VCDS Map User
    712
    66
    I had similar problems finding a module.
    However, I did find there was a module number - from Bosch - which you have, but also a pump assembly number from Audi (8E0614111B is an example) I found there were many more pump assemblies than modules for sale, and the cost was about the same
    You need to get the correct number for your car - if you have Elsawin there is a table of pump numbers against car model so you can get it there. (My copy is playing up, sorry)
  3. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,819
    197
    also depending where abouts you are there is bound to be a local member able to code the module in for you if its needed.
  4. aragorn
    18,608
    871
    Module doesnt need to be coded, it just plugs in and works.
    Your best off looking for whole pumps ending in A or E, and swapping the module over.
    They're used on a few cars like the A6 and A8 as well as the A4. It must be from a quattro and must be pre-ESP. If you stick to looking for pumps ending in A or E you should be fine.
  5. boost-addict
    1,000
    39
    Oh really!! Ok so a4-a6-a8 pumps ending in a and e..
    If i get a few together can i link them to you and you tell me yes or no.
    Oh on a side note got the fly wheel going to the machine shop this month.
  6. aragorn
    18,608
    871
    yeh just match the part number, if it matches it'll work.
  7. boost-addict
    1,000
    39
    this is the problem ive been having mate.
    the only info i have is the part number from the module 0 273 004 284
    and obs the part number on the pump
  8. Sulli79
    Sulli79 Active Member
    541
    37
    Try 8E0 614 111 A or 8E0 614 111 E
  9. boost-addict
    1,000
    39
    thanks, looked on ebay..... ha, presume you havent seen the modules that aint on there,
    theres one but £240, why i dont know
    Audi A4 ABS Pump And Controller - 8E0614111A - 8E0 614 111 A | eBay
    other then that its a return and replace which clearly i dont have! but then reading the ad, its got hidden charges writtten all over it
  10. boost-addict
    1,000
    39
    just emailed and asked why it was £240 etc
    this is the reply
    hi its down to availability and how scarce they are i am the cheapest on ebay for this model
    i hope this answers question
  11. boost-addict
    1,000
    39
    so making it £100 more just becasue there few and far between!
  12. Sulli79
    541
    37
    Just keep looking, I sold one for £40 because that's what I thought it was worth.
    might be worth checking SRS classifieds as a couple of S4's were/are being broken
  13. boost-addict
    1,000
    39
    ah right ok
    yer been looking for breaking a4s too
    now you understand my pain!
  14. PAULF
    712
    66
    It took me a while to get mine, I can't remember what I paid in the end but I think £50 or less.
    (Mine was a 8E0 614 111 E )
    Try a few scrappies too - the bay of 'E's is starting to get a bit rubbish for finding stuff
  15. boost-addict
    1,000
    39
  16. Sulli79
    541
    37
    That's the one. Have you mailed him to check its ok not to return a module?
  17. boost-addict
    1,000
    39
    well he says:
    • You may not purchase this listing without an intention to return a functional core.
    but it says $150 (£91) so if you was returning a module it would be $100 (£61)
    but what would you do?
  18. Sulli79
    541
    37
    Personally I would let him know the situation with your module being lost and see what he says, it may be that he only has a small turnover of these units and would probably be quite miffed with being down a unit. But ultimately it's your call
  19. boost-addict
    1,000
    39
    i dont want to do an one over, id be pissed if some one didnt send me back a module
    but on the other hand i dont wanna loose this by him closing the door on me
    really dunno if to be considerate or selfish !!
    im not a selfish person so dunno.
    unless i email him from an other account and say what happens if i dont have a module
  20. boost-addict
    1,000
    39
    ok went back though my service paperwork etc, as i know lynx services replaced the module in 2009, i didnt actually see this the first time, but have a receipt for £300 for exchange abs unit 0273 004 284/X
    company
    lynx automotive ltd
    nottinghamshire
    also on a plus side discovered it had a oil pump fitted 35k ago! bad news is ive realized i have cam belt due in 600 miles lol
    any way still on the hunt for one any people know any more suggestions?
