Need Help quick PLEASE!
connasm Nov 25, 2013
  1. connasm
    connasm New Member
    I have a 05 A4 2.0 TDI.
    The problem is it's hard starting when its warm, and only when it's warm. It will turn over 5 or 6 times at least. And when it does, the bremse light will flash 3 times and go off!
    I have the car two months and it's being doing it since the start. I bought it off a garage, I got warranty with it but its up in two weeks time. I had it in with them twice, They changed the coolant sensor and they checked the starter and there was nothing wrong with it.
    I was just wondering what other avenues there could be to solve this problem as I want it to be fixed.
    Also, is my warranty still worth anything after it runs out even though they haven't fixed it during my warranty, will they still have to fix it.
    Any help would be greatly appreciated! :)
  2. sidibear
    sidibear Looking for Zombies !! Staff Member Moderator Audi A4
    2,320
    768
    Did you change your coolant temp sensor as per the advice in the last thread you started?
  3. JimmyH
    JimmyH Active Member
    374
    73
    If the issue was raised during the warranty period and there is still the same problem outside the warranty period they are obliged to fix it.
  4. connasm
    connasm New Member
    Well the coolant temperature sensor was changed by the garage so I presume it was done right. On my last thread you said about the breather hole on the filler cap being blocked, would this just be a problem when it is warm? Really want to get this sorted, wish it was just something simple!
