need help plz got quite a big problem and its getting worse
davidniclee Oct 19, 2011
  1. davidniclee
    davidniclee Member
    96
    well here goes my audi a3 1.8 20v turbo started running a bit crappy when ticking over a bit like a shudder now and again .but when driving it was fine . then it started afecting it when i was driving dont no how to word it but it was like it was having the fuel cut off then fuel came threw surpose hesertant would be the word .but now i have almost no power and when i stop the revs drop down from 1 notch under 1rpm to about the 3rd notch up from the bottom of the rev counter think that would be 300rpm and its virtuly about to cut out.when i start to pull of it jumps and jerks like when your 12 and learning to drive and carnt control the clutch thats the only way to explain it really.
    right just so you know i changed the plugs iv changed the maf and iv cleaned the throttle body and all that made it worse bit by bit till the point im at now.
    but here is the massive problem. i took it to a friends garage he has a snap on diagnostic machine we planed to plug it but found that the ecu plug where you plug in the diagnostic plug. had been cut off please help plugging it in is out of the question unles someone on here could tell me how to rewire the 4 wires 1 red white 1 grey and white then 2 solid browns i dont know where the browns go
    any help would be great thanks dave please help
  2. davidniclee
    davidniclee Member
    96
    anyone got any ideas
  3. liquids3
    liquids3 Member
    930
    22
    Id say check your boost pipes,vacume pipes!,get a pressure check on those hose's (or listen to them see if any are leaking)(around inlet manifold,turbo pipes ect),check coil pack's!,id sort the diag port last if not(just get a new port and then you can find diagram ect!,id say vacume pipes though!
  4. A3 T
    A3 T Lord Of The Rings
    1,077
    15
    Have the wires just been cut?
    If so are the brown wires the exact same thickness?
  5. jojo
    29,001
    3,657
    What year is the car? Why would anyone cot the diagnostic port off?
  6. warren_S5
    warren_S5 Moderator Moderator VCDS Map User
    7,210
    2,488
    Blcoked fuel filter?
    Injectors need cleaning?
    Fuel pump failing?
  7. Broken Byzan
    13,244
    468
    coil packs?
    blinker fluid?
  8. Gops
    3,198
    666
    Maf? The same happened to my cousins 1.8tqs.. Juddering, loss of power etc..
  9. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    Where did you buy the MAF from?
  10. davidniclee
    davidniclee Member
    96
    yes its a clean cut and the brown wires are the same size
  11. davidniclee
    davidniclee Member
    96
    its a 1998
  12. davidniclee
    davidniclee Member
    96
    whats blinker fluid
  13. davidniclee
    davidniclee Member
    96
    i changed the maf about 3 days ago
  14. davidniclee
    davidniclee Member
    96
    ebay it was 24.99 posted
  15. Broken Byzan
    13,244
    468
    in which case could still be the MAF, the cheap ebay ones are rubbish sadly
  16. davidniclee
    davidniclee Member
    96
    great more money wasted where the best place to get one do you know or have a link
  17. Broken Byzan
    13,244
    468
    I have leanrt that as an expesnive mistake, best cure was an OEM one from the stealers. I went through 3 Ebay ones all exibited differing problems, ie didnt idle, low power and combinations of both. Bought a genuine one and it was perfect.
    I would look at starting it up, and carefully remove the injector plugs ? or coil pack plugs one at a time to see if you can trace the cylinder thats misfiring. Then if that works, try swapping the coil pack on that cylinder to another clyinder and see if the miss moves with it.
  18. davidniclee
    davidniclee Member
    96
    could i get a shock off the coil packs heard of this before been told i hurts like mad also what would a genuine maf cost at the stealers
    one good thing i have a stealer about 1 min drive from me
  19. Broken Byzan
    13,244
    468
    no shock from the low voltage side for sure, they are telling you what olde plug leads were like.
    If unsure i'd remove the injector plugs.
    Depends on the MAF you need, but i would expect it to be around £80 exchange
  20. davidniclee
    davidniclee Member
    96
    my maf says on it bosch 0 280 217 117
  21. Broken Byzan
    13,244
    468
    Thats the common one iirc, should be the most affordable, so shouldn't be more than £80. But you'd have to conatct the stealer and ask
  22. davidniclee
    davidniclee Member
    96
    gona go and try the coil pack pulling out thing now just gota find my head torch lol will update you in 20 mins ish thanks for the help so far guys
  23. davidniclee
    davidniclee Member
    96
    will do dreading it a little bit tho
  24. davidniclee
    davidniclee Member
    96
    right took 1 coil pack off and there was no change i started from left to right one by one and it was the same all the way threw the packs engine was still running crappy so i took off the first 2 coil packs and it was still running pretty much the same now that worries me a bit i took 2 off in differant combonations and it still runs so put them all back on i then unpluged 1 injector and it run the same unplugged 2 injectors and it run like **** but didnt cut out.
    how can my car run wioth 2 coil packs taken off iv never seen a car do that before iv seen them run with one off but not 2
  25. liquids3
    liquids3 Member
    930
    22
    Wel if you take the coil pack of and theres no change in engine tone then it might be gone,best thing to do is cylender by cylender take a spark plug out put into your coil pack,put the plug against the rocker and turn over see what spark you are getting,best way to check plugs coils!!,have you checked for split vacume hose's?
  26. davidniclee
    davidniclee Member
    96
    im not 100% sure where the vacume pipes are i changed one that runs from the inlet manifold round to the back of the engine past the tip it was leaking but now its fine
  27. davidniclee
    davidniclee Member
    96
    also i orderd a maf from the dealers it will be in monday noon its costing £102.30 what a rip off just hope it will fix it.
    right on my way to work this morning my car was running really bad but the weird thing is on my way home from work just now the car run like new with no problems it had full power no jerks no missing nothing it was just perfect
  28. sportquattro
    sportquattro Active Member
    845
    51
    If you give them your old MAF back you should get it for less as its an exchange item, I did when mine needed changing 18 months ago.
  29. davidniclee
    davidniclee Member
    96
    that is the price with giving mine back
