need help guys
billybravo Jun 15, 2007
  1. billybravo
    billybravo Active Member
    1,045
    ive got a 2 probs with my 1.8T
    1. the car idles fine and also drives ok but as soon as i hit just over 0.6 bar of boost the engine is really slugish like its farting as it tries to make more boost the prob gets worst like a missfire but i dont think it is.
    2.also while im here i replaced my coolant sensor last month the 4pin black one but my gauge only seems to work when it wants to. is the gauge on a diffrent sensor. there is a blue sensor with 2 pins next to the black 4 pin one could this be it
    cheers
    craig
    Also i dont have any codes coming up on vag
    help please
  2. billybravo
    1,045
    well to cure the second prob im going to get a new stat coz i think its sticking open.
    but i still cant slove the first prob HELP !
  3. PaulJC84
    PaulJC84 Owner
    2,922
    17
    You checked your spark plugs?
  4. billybravo
    1,045
    no
  5. billybravo
    1,045
    checked the plugs there fine i dont think it has anything to do with the igintion side of things could it be the fuel pressure reg?
  6. billybravo
    1,045
    ok ive found today that this only happen under full load the car hesitates then picks up
    any ideas
    thanks
    craig
  7. hiltoa
    hiltoa VAG erfahren
    298
    Squishy inlet pipe collapsing under boost?
  8. billybravo
    1,045
    i think it could be my mass air flow meter does anyone have a write up on how to clean them
  9. jimya4t
    jimya4t Member
    75
    i had the same problem. is it fine if you dont put your foot down and let it build up? does it just happen when you floor it or even just a bit? mine done this like i was kangarooing the car lol and it ended up it was the N75 valve. could be this?
  10. billybravo
    1,045
    cheers i will have alook i did check it on vag and i could hear it working ok but i will swap it for one out of my mates see if that works
  11. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    Does sound like a dodgy plug to me, had the same problem, different car and it was the plugs.
  12. billybravo
    1,045
    ok ive ordered a new set ngk bk6e's which i will set at 0.28 gap and im going to be getting a new maf tomorrow from eurocarparts or gfs parts lets hope all this does the trick
