Need help diagnosing problem
scream
Hello.
I'm having some trouble with my 2007 Audi TT MK2. About one month ago my cam belt broke and did some serious damage (all 16 valves were bent). Had all this fixed,cylinder headwas redone, new gaskets, etc...
When i went to pick up my car the mechanic said everything was fine and he had driven it around the block a few times. When i started the car it was idling rough and i could hear a whistling sound, i went back to the mechanic and he said that it would pas. A few hours later after driving it for a bit a CEL would come on, I used torque to check the code and it gave P0171. I called the mechanic a few times to have him look at the problem but he's been giving me excuses that he doesn't have any time, on one occasion he told me to bring the car and i left it there for an entire day without him even taking a look at it.
I've tried to figure out what the problem could be with the help of this and other forums, websites.
I found out that the most likely suspect is a vacuum leak so i looked around and sprayed with some brake cleaner and couldn't find a vacuum leak.
Changed MAF and air filter.
Changed PVC (with a non OEM one)
When i drive it, it doesn't seem to accelerate the way it used to. Also when i drive it while the engine is cold and release the gas i sometimes get loud pops from the exhaust.
The whistling noise stops after driving a few seconds or reving the engine a few times and the idle also becomes smoother (video wil make that clear)
The idle also improves when the CEL is on.
First video shows the idle on startup and you can clearly hear the whistling sound
second video shows my torque app gauges
https://drive.google.com/file/d/0B0T...ew?usp=sharing
Any help with this matter would much appreciated
If you've changed the maf then it's got to be a leak really mate
Get a smoke test done, You probably have a vacuum leak somewhere. Fairly poor show from the garage where you took it that they haven't been able to resolve the problem. Unless they know that it's more than a vacuum leak.
I use a piece of plastic pipe to look for vacuum / pressure leaks. One piece in your ear the other move it around the various places on the engine where you think the leak may be.
