need help asap! about my lowered a3
audi-tk Sep 29, 2010
  1. audi-tk
    audi-tk Member
    441
    my a3 is lowred on coilovers and the driveshaft has broke 2 times now! the gearbox still spins but it aint spinning the actuall shaaft, could this do with the car being to low? havent got a whiteline arb ordroplinks.think its only lowered 45 - 50. geting fed up with this now!!! any help be appreciated, thank u
  2. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    its too low mate. i had to get eibach arbs to clear it properly. now i have no problems with even 4 ppl in the car. raise it until u can get a new arb
  3. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,260
    357
    ah :)
  4. audi-tk
    audi-tk Member
    441
    would you say its that causing the problem? drivehsaft ,all the bearing at the end of the driveshaft where ti goes into the gearbox have all grinded away.not even balls any more lol
  5. S3quatt
    S3quatt Flat Oot like a ducks Foot VCDS Map User
    652
    58
    Hehe "Boy racer" springs to mind in this case...
    The whole lowering topic has been covered time & time again & some folks never learn... I did, years ago & learned the hard way...
    If you're going to lower a car, do it right & dont just chuck on a set of springs..
    Oh & I have a set of standard S3 ARB's which might help :yum:
  6. audi-tk
    audi-tk Member
    441
    ive got coil overs mate
  7. bhavin1986
    bhavin1986 BBP
    464
    I had a Little ARB against driveshaft rubbing. Was worried of a broken driveshaft so removed the arb altogether! I know people on here will look down on this, but there is no noticable difference in the handling without it. And as long as you remove all remnants of the arb including the droplinks you shouldn't have any MOT issues either. Many GTis are running without ARBs over on E38. I just used an angle grinder to cut the ARB near the bend near the subframe, removed the droplinks and bushes and pulled the ARB out. Job done! No more issues...
    May fit a whiteline ARB once they're back in stock
  8. audi-tk
    audi-tk Member
    441
    will look into that.but be better to get the tt arbs ? cheers
  9. Prawn
    11,455
    3,352
    stop making random guesses at things!
    Do it properly, or raise it back up.
    To fit a TT anti roll bar you'll need TT/S3 front struts, as the ARB mounts to the coilover body and not the wishbone. this if effort that you don't need to go to.
    Buy an uprated anti roll bar with larger hoops and your problem will be solved.
    Don't just remove the ARB totally, that's fine if you just want the looks, but it's a bad idea for the handling.
  10. bhavin1986
    bhavin1986 BBP
    464
    Agreed. If you do remove the anti roll bar do not gun the car around corners. I have done this for the looks and being a 1.6 do not drive the car too spritedly.
    Wanted to eradicate the rubbing issue before the whitelines are back in stock without having to wind the coilies up.
    Although on a sidenote, my theory is if you remove the ARB and wind the coilies down the car's centre of g is significantly lower which should reduce the instability of removing the ARB.
  11. gavin89
    gavin89 Wana go Low gotta go Slow
    214
    Erm maybe to a certain extent, but I don't agree. The purpose of the ARB is to reduce body roll, even if your centre of g is low, it doesn't fully counteract the compression of the suspension when your car goes around a bend. With an ARB fitted, the lower part of the suspension movement relative to the car chassis is transfered onto the same component on the other side, so [SIZE=-1]the twist torque of the anti-roll bar always tries to fight against the compression, therefore reducing roll. Also on situations where both of your wheels aren't level, i.e [/SIZE][SIZE=-1]one wheel is riding on a hump, the anti-roll bar will be twisted and transfer the force to another wheel to push it down, so the car body will remain balanced. Without ARB, you wont get any of those benefits...So i recommend you still fitting one :p
    [/SIZE]
  12. audi-tk
    audi-tk Member
    441
    yeh ill stick to keep mine or buy an uprated one lol. try and find a second hand one if any1 is selling any cheers for help peeps
