NEED HELP... 2.0 tdi smoking low revs
Salt_258 Mar 25, 2014
  1. Salt_258
    Salt_258 Member
    30
    Brought an a3 2.0 tdi at the weekend for the girlfriend, everything seemed great, high miles but full service history timing belt done etc etc, couple of days on and she's noticed the car is smoking whitey blue smoke at low revs eg first to second and to third, i took the car out and thought maybe it needed a blast, bit of a blow out, but I found it didn't smoke at all under heavy acceleration, only when low revs 1200 - 1800, it's as though when the turbo isn'tworking it bbegins smoking, any ideas thanks very much
    Mileage is 146k 2003 reg
    140 bhp model
  2. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    make sure your not losing coolant ?
  3. Salt_258
    Salt_258 Member
    30
    I checked coolant Sunday prior to buying the car, I also checked it twice tonight and seems to be at the same level... Could it be oil in the intercooler? The problems is only seen when pulling off in first then changing to second, especially can be seen when letting foot of the accelerator!
  4. tdi-man
    1,783
    64
    keep an eye on levels m8 . may be turbo seals .
  5. Salt_258
    Salt_258 Member
    30
    Thanks for your replies, do you think continuing to drive and see what happens would be best, or should I take it too the garage?, beginning to think I may have been sold a bad one, any come back vs private seller?
  6. tdi-man
    1,783
    64
    take it to a garage and get a proper check done on it , to recon a standard turbo you looking at 600 ish fitted and if your losing water which I don't think u are cause your levels aint dropping is possibly a new head ;(
  7. Salt_258
    Salt_258 Member
    30
    Thanks for the help, anyone know of a very good vag garage? Derbyshire, Derby area?
  8. Salt_258
    Salt_258 Member
    30
    Took the car to sunset Vag in Derby, turns out the fuel filter was fitted incorrectly and damaged, also there is oil in the fuel due to a faulty tandam pump, he's told us to use the current fuel up and stick some v power in and see if it gets better, should we just get the tandem pump replaced? Does this information sound correct? Thanks
  9. Salt_258
    Salt_258 Member
    30
    Ok so serviced the car Saturday oil, filter, fuel filter, still the same, light blue haze smoke from exhausts especially on the over run low revs 1st n 2nd gear
    Took it to another guy who thought it was fuel read ecu no codes found,
    Decided use all the fuel up and stick v power in so we have done that and seems possibly slightly better
    Removed fuel filter so that I could add forte diesel cleaner, noticed in the excess fuel little tiny black bits would this be oil?
    Could I have a fault with tandem pump ?
    Please help it's really hard to find someone good at this engine it seems in my area at least
  10. tdi-man
    1,783
    64
    hi your fuel filter will always go black as its a diesel and that what they do .
    mine has always done it and always will.
    replaceing tandem pump wont stop the filter go black.
    keep using a fuel cleaner will help
  11. tdi-man
    1,783
    64
  12. Salt_258
    Salt_258 Member
    30
    Thanks for the link,
    Maybe it is the turbo....
    Is seems to smoke on overrun?
    Best vag specialist in Derbyshire?
  13. tdi-man
    1,783
    64
  14. Salt_258
    Salt_258 Member
    30
    13 months old previous owner had it done, and I've checked with the company it checks out....
    I've done alot of checking on the Internet and people mention the pcv valve being blocked, my symptoms sound very simular....
  15. tdi-man
    1,783
    64
    ok with engine running take pipe of pcv valve on the rocker cover and see if your getting oil / smoke / pressure come out of it ?
  16. SmithyAG
    SmithyAG Active Member
    414
    61
    As above, at idle it should puff a faint haze with the breather pipe off.
    If it is the tandem pump it's cheaper than turbo but still about £200 for the part.
  17. welshd1k
    welshd1k Member
    155
    mines started doing this last week interesting to hear I think its oil from the breather on the top going back into the turbo its worse after its parked up for 2-3 miles then clears but if I park up and leave for 30 mins jump back in its the same again . and its clouds of smoke if I give it a boot full in 2nd
  18. Salt_258
    Salt_258 Member
    30
    Sounds very much the same have you replaced anything yet?
  19. tdi-man
    1,783
    64
    you can fit an oil catch can which will help with this .
    just sorting mine out . pipe work isn't finished
  20. welshd1k
    welshd1k Member
    155
    tdi man I was looking at these along with egr blank :) . and I haven't done anything with mine yet tbh . I thought it was turbo but been told if it was turbo it would be all the time >< so yeah umm . thinking oil catch tank may be a fix as there was some oil in the breather pipe etc . but I may try it with the pipe off and airbox side blocked and the cover side piped into a bottle for a few days see if it cures it
  21. tdi-man
    1,783
    64
    can you just block the air box side ?
  22. welshd1k
    welshd1k Member
    155
    yeah but then id have oil under my bonnet / engine from the breather wouldn't I ?
  23. tdi-man
    1,783
    64
    im only fitting oil catch can to help keep my engine in tip top condition as I have have a new head fitted last year also had new piston rings and shells etc.
  24. welshd1k
    welshd1k Member
    155
    yes but if I was to disconnect the brather to test if it was breathing oil through into the intake it would lead to oil being blown out over my engine bay while driving?
  25. tdi-man
    1,783
    64
    no you will get very slight chuf and hardly any oil
  26. abooo
    abooo New Member
    9
    did this issue get solved ??? was it the oil going from the breather back into turbo ??? my oil is over the max mark could this be causing the problem
    thank you
  27. Salt_258
    Salt_258 Member
    30
    Could be , my girlfriends car was using more than ltr every 500 miles it was the turbo in the end
  28. abooo
    abooo New Member
    9
    completely stop smoking ?? did it get worse as you carried on driving ?? my turbo feels fine and pulls like a train just this ***** smoke covering the street when I stop then go again or reverse .... hmmmm my turbo was changed 2
    months ago it still has warranty ... I'm thinking either turbo seals or valve seals
