Need clarification & advice on the following
mathew lisett
The car is a audi a4 b7 2.0 tfsi se
MASS AIR FLOW Meter
(been told by audi that its faulty and running lean so need a new one , so need clarification this would be the replacement and more up to date revision)
is this item also already in the uk?
http://www.europaparts.com/mass-air-flow-sensor-06d906461.html
cam-chain-tensioner, how easy is it for my local garage to check to see if this needs replacing? and is this the current revision.
http://www.europaparts.com/cam-chain-tensioner-service-kit-2-0t-fsi.html
PCV, is this the current revsion and how would the garage know if the one on the car needs replacing
http://www.europaparts.com/breather-update-kit-a4-b7-2-0t-early-vin.html
clutch line,are there any better ones?
https://www.earls.co.uk/earls/preassembled/clutchlinekits/carclutchlinekits.html
gas-tank-cap,is this the current revision
http://www.europaparts.com/gas-tank-cap-4f0201550j.html
coils,is this the current revision
http://www.awesomegti.com/red-ignition-coil-pack-set-2-0tfsi
thoughts, the rear shocks need replacing so i have decided might aswell do the front and rear, are these a good set
http://www.awesomegti.com/car/audi/...avant-b6-b7-8e-with-sport-suspension-11-00-07
Do i get 2 of these or do they come in dual packs? for the front and rear,and whats the difference in power between 255 and 288 (think those were the sizes)
http://www.larkspeed.com/shopper/i/...lack-Diamond-Rear-Brake-Discs-Grooved-Drilled
http://www.larkspeed.com/shopper/i/...ack-Diamond-Front-Brake-Discs-Grooved-Drilled
http://www.larkspeed.com/shopper/i/...m-Disc-Black-Diamond-Predator-Rear-Brake-Pads
is it just one set of these or do i need how many for front and rear for the brake lines
http://www.larkspeed.com/shopper/i/23DHK622
econ light always on., anybody know as to why?
was told their a suspected air leak from the engine, would this be the pcv or something else?
Best advice I can give you if you need OE parts is head over to the ASN parts ordering system.
http://www.audi-sport.net/xf/support-tickets/list - Mike can also look up exactly the right parts for your car.
I happened to just get a new Maf but it turns out it makes no difference to my vcds logging (both go to same G/s) or fuel trims so have a used one going, if you are interested then message me. My used one is from a 2010 car, 55000 miles.
Econ - does your aircon need a regas?
Air leaks can be difficult to track down - what information was this based at and what are the VCDS block 32 fuel trims?
the link you provided gave me "The requested conversation could not be found."
also i spoke with my local garage (not audi) and they said the econ light likely needs the pressure switch replaced.....and possibly a re gassing, but definitely the switch since you cant switch it off.
couldnt give you much info about the air leaks because the tech at audio in salisbury were not exactly helpful, ie the poor lady that was dealing with me pretty much spent near an hour going back and fourth gaining info when they could and should have just noted the stuff down as i had already requested.
I have however emailed their service supervisor with questions in the hope ill get somewhere, because today i had some new spark installed but it still is feeling a bit rough which even the garage guy said when he took it for a test drive after correcting the steering.
