Need advise
stevehart Jun 26, 2006
  1. stevehart
    stevehart Bring on the Ice!!
    59
    I Just bought a 52 plate S3 last week and have just been getting the feel of it.
    I took it out for a spin the other day. In the dry it bit well into the corners and felt pretty tight. However, when the roads became wet the car started spinning and sliding in the corners, even at low speeds. I have checked the tire pressures and they were at the recommended 34 psi (as indicated inside the filler cap). This seems a little high to me.
    Can anyone help or have suggestions
  2. Stewart
    Stewart Member
    705
    10
    Correct tyre pressures, especially on 18's, some on here will recommend 38psi at the rear to promote a little oversteer...
  3. Grant
    Grant Well-Known Member VCDS Map User Audi RS3
    1,206
    118
    17" wheels should be 32psi, so I'm guessing you have 18" alloys?
    The S3 is prone to understeering, so try lowering the front psi to induce more grip. I used to run 30psi front and 32psi rear on 17" wheels. With 18" wheels try 32psi front and 34psi rear.
  4. stevehart
    59
    Thats far doo's i guess,
    But with 4WD I was expecting it to be pretty sure footed in wet conditions.? or did I just believe the hype?
    I dropped the pressures to 30 to see if it would make a difference but haven't had a chance to test it yet.
  5. stevehart
    59
    Yeah they are 18's.
    Cheers for that, i'll give it a go
  6. AndyMac
    9,832
    45
    Also tyres make a big difference. If you're running Dunlops then it's a miracle you haven't written it off yet.
  7. dickys3
    2,954
    I second that!
    I've got them on my car and they are rubbish in the wet!
    What tyres have you got mate? Please Don't say Avon ZZ1's either!
  8. madvw
    madvw Active Member
    2,489
    I'm going to be in the market for some fresh rubber soon, and the tyre choice really can make or break a cars handling.
    The OEM choice for S3's is Bridgestone Potenza RE040's, and I really don't have a problem with them, they last ages, give really nice grip in dry and wet and are really predictable.. even with the recommended pressures for OEM 17" Avus rims..
    Is it just me, or am I missing out on something real special with the Goodyear Eagles?
  9. s3bow
    s3bow Member
    379
    Got Dunlops on mine. Nothing wrong here. SP 9000 though. Not the ones you find standard fit. Like you said Rich, hope they are not Avons ! Although I have to say, these dunlops are getting as noisy. Directional !
    Chris.
  10. stevehart
    59
    the rear two are accelera (never heard of them) and the fronts are dunlops
  11. Olly_K
    Olly_K Administrator
    2,678
    get them all changed.....to the same make for starters, goodyear eagle F1s get my vote !
  12. sprout99
    sprout99 Member
    373
    best i've had are Toyo T1R's - very grippy in wet and dry
    i learnt my lesson with cheap tyres about 3 years ago.
  13. dickys3
    2,954
    I think you may have found your problem mate...
  14. stevehart
    59
    Cheers everyone,
    That really is helpfull. Such a great site this! been looking for an S3 forum ever since I made up my mind to go S3.
    Happy again!
    By the way, about how much will a set of Toyo T1R's set me back?
    Steve
  15. icenutter
    icenutter Member
    596
  16. dickys3
    2,954
    Also try mytyres.co.uk
  17. AndyMac
    9,832
    45
    It's probably the Accelera's that were keeping you on the road at all.
    Get a guide price from black circles then call the local fitter they recommend and get a better price from him, you'll save a further £10-£15 per tyre.
  18. ChriS3
    ChriS3 hud at ye bam
    2,239
    24
    Seconded - Best way to get tyres cheap! The F1's are about the highest rated on the S3, - I'd say the Yokohama Parada Spec 2's have better grip but they won't last as long.
  19. S3_MCD
    S3_MCD Member
    389
    Ive run Eagles GSD3 for years.... definately the best all round tyre in my IMO.
    Excellent in both dry and wet, only thing you need to be aware of they work better with a little heat in them and as such can be a little slippy on slimy roads when the mornings are cold - need top give 10 mins before the confidence is there.
    Other than that you can get 15K plus from a front set (even with a weekend at Nurburg!).
  20. god_thats_quick
    2,507
    I agree - big eagle F1 fan here! superb in the wet, 4 hours on motorways the other weekend in horrible weather and standing water with 4 in the car + luggage at anywhere between 70 - 110 and felt planted on the road the whole time!
  21. AL_B
    AL_B Well-Known Member
    1,606
    27
    My car had the RE040's when new too. They were ok in the dry, but I found the car understeered badly in the wet. Once I changed to Goodyear F1's, the difference was incredible. Honestly. In the dry the grip is superb, and in wet weather they just give you more confidence. When the front does start to go, its progressive too, and easily controlled with the throttle.
    I'm on my second set now, and I reckon 15K miles aint to bad from a sports tyre. If you rotate your wheels front-to-back etc. you can even the wear out between front-to-rear, and get a few more miles out of them.
    I found that their performance was noticeably worse when 1-2mm about the tred wear indicators. So I got a new set. I guess I could have got another couple of thousand miles out of them had I not changed early.
    With regards to pressures. I run 32 front, 34 rear, on 17's.
    If the handling still feels funny after changing the tyres, get an alignment check done. Get them to check the bushes and torques on your suspension, anti-roll bars etc.
    AL
  22. Grant
    1,206
    118
    I liked Michelin Pilot Sports
  23. TDI_Boy
    TDI_Boy Member
    51
    I liked the Michelin Pilot Sports on my golf. I think they were Piloit Sport IIs but I don't know if there is a difference. Possibly not quite as grippy as the Goodyears, but I do 25k - 30k a year, and the thought of a complete new set of tyres every six months rather put me off. The Michelins lasted well, and were good and grippy. The A3 will be getting them as soon as the crappy ones the dealer put on before I bought it are worn out....
    Mark
  24. PaulRS3
    PaulRS3 Well-Known Member
    1,209
    141
    I havent read all the threads inbetween, but my 2003 S3, with factory 18" tyres on the lighter of the two loads, is 36 PSI all round.
