Need advice on what else is needed with coilovers?
Daws88 May 9, 2011
  1. Daws88
    Daws88 Member
    246
    I am looking to get some of advice about what is needed to accommodate coilovers?
    I am only going go get budget coilies, probably joms for the time being, as I want my speedlines on asap!
    Will save up for a premium set in the future.
    So I am just wondering what I shall need to replace or upgrade? Top mounts etc? Greasing the coilies?
    Any help would be appreciated! :)
  2. N8
    17,163
    718
    You will need to tape up the coilys, and there is no point buying 2 sets just get 1 set and leave that on there lad.
  3. Daws88
    Daws88 Member
    246
    Well I was thinking of the joms as a tempory as there an affordable price at the moment, until I save enough for air perhaps :hubbahubba:
    Could you explain further about taping them up? (complete noob at the mechanical side of things!)
  4. Farhan
    Farhan Active Member
    1,234
    57
    Its good practice to tape up the threads on the coilovers, It will protect them from rust and wear. Basically a spring will sit on two locking collars these locking collars spin across a thread to adjust the height. If the threads rust it can be a nightmare adjusting the height in the future.
    Using a tape is always good practice to help keep them clean, In the past i used to use a silver copper grease which worked well and often every 2-3 months gave them a good clean and regreased the threads.
    An example below,
    Tape is often better than grease as the grease can sometimes hold little stones etc
  5. N8
    17,163
    718
    Yep! ^
  6. Dan.
    Dan. Member
    59
    on my bora i used a peice of neopryne (wetsuit material) as a sleeve over my coilovers, as well as lots of belzona anti seize, worked a treat for the best part of 2 years until i got lazy,
    but yeah tape is a good idea never thought of that!!
  7. N8
    17,163
    718
    Dan you up for a meet soon?
  8. Dan.
    Dan. Member
    59
    Definately Nath, been mega busy recently but still need to come see you guys!
    When you thinking?
  9. N8
    17,163
    718
    Not sure, quite a few NW A3s now, so we'll have a good turnout.
  10. Dan.
    Dan. Member
    59
    Yeah definately, I go away a week on Wednesday for a week, and Jord is away at the minute so well have to arrange something when were all available,
  11. N8
    17,163
    718
    Yeh no worries danielson
  12. Daws88
    Daws88 Member
    246
    Thanks for the picture and advice farhanali.
    By the sound of things the tape sounds the best route to go down, what sort of tape lol?
  13. N8
    17,163
    718
    Sellotape
  14. Lings
    Lings Active Member
    2,059
    31
    N8 told me to use tape on another thread and it got me thinking ...I will be using self amalgamating tape on mine
    Self Amalgamating Tape .
    its rubber you can stretch it over things and in threads its ideal for the job .It will also keep it sealed water tight .
    Now i just need to get some energy to clean the greece off LOL
  15. N8
    17,163
    718
    N8 chats a load of ****, don't listen to him :laugh:
  16. Daws88
    Daws88 Member
    246
    Thanks Steve. May try that myself. Would it be worth my while putting grease on aswel as the tape or not?
    Would I need to upgrade my top mounts?
  17. flying oyster
    flying oyster flying oyster
    563
    27
    did top mounts and rears as well all in 50 notes from europarts made life easy .
    :banghead:saving for the rubber for my speedlines
  18. Daws88
    Daws88 Member
    246
    Thanks. I am also saving for rubber for mine aswel, but going to get the coilovers done first.
  19. TimG
    TimG Active Member
    942
    45
    I've copper greased mine for now. I'll probably give them a good clean, re-grease & tape them up at the end of the summer before the weather turns poop.
  20. Daws88
    Daws88 Member
    246
    So the tape is the way forward! How are your joms now Tim?
  21. Lings
    Lings Active Member
    2,059
    31
    Really ? :p
  22. N8
    17,163
    718
    Yeh :laugh:
  23. TimG
    TimG Active Member
    942
    45
    They've been fine. I had the tracking done the other day after about 400 miles and thats actually made a positive difference to the ride, feels smoother than before. Wheels were toeing out a bit, rather than in slightly so werent running smoothly over bumps etc. Mrs thinks my car is bumpy, but she's said that about all my cars with coilovers & compared to her polo daily I guess it is tbf.
    I was gonna raise the rears a little today in line with the front, but appears I'm going to need to take the wheel off and take the adjuster out to be able to adjust it, which I couldnt be bothered with today, hehe.
  24. N8
    17,163
    718
    Always get full alignment and tracking done, saves tyre life as well.
  25. TimG
    TimG Active Member
    942
    45
    Was quite interesting to get it on the Hawkeye tracker and check out the readouts. Camber on the fronts is -1.23 degrees & 2.2 degrees on the rear, purely as a result of lowering. Not sure what the Audi spec camber is, but I corrected the toe & left the camber as it looks good! :laugh:
  26. FranA3
    FranA3 events moderator Regional Rep Gold Supporter Audi A3 Team Brill Red
    7,228
    320
    i still need to get mine done lol done nearly 2000 miles now yes i know im lazy lmao
  27. Scott_Hol
    Scott_Hol Member
    584
    The coils ive got on are stainless steel so apparently no rusting would it still be worth me taping up my threads?
  28. TimG
    TimG Active Member
    942
    45
    Yeah, I think my Konis on my TT were stainless and they siezed to poop!
  29. Lings
    Lings Active Member
    2,059
    31
    For the cost of them. i would still tape them ...
  30. N8
    17,163
    718
    I never taped my KWs, and they were fine Scott!
  31. FranA3
    7,228
    320
    what are v-maxx like n8 ive greased mine will that be ok or do i need anything else
  32. N8
    17,163
    718
    Shud be ok, or you can tape as well, Karl used tape on his, seem to have been fine.
  33. FranA3
    7,228
    320
    cheers n8 , not that im going to be raising her up or anything lol , haha ash said the other day when i got my coilovers i would only lower her about 30-40mm now she is all the way down see i couldnt resist the lows lol
  34. N8
    17,163
    718
    :laugh:
  35. Shane.
    Shane. Member
    486
    I got some brilliant self emulgamating tape ideal for water sealing problem is it don't like coming off once it's on
  36. FranA3
    7,228
    320
    good stuff then shane
  37. Scott_Hol
    Scott_Hol Member
    584
    Yea your probly right m8
    How long did you have them on for nath did you do out else light greasing or cleaning?
  38. Lings
    Lings Active Member
    2,059
    31
    Brand new stanley blade and a steady hand ;)
  39. N8
    17,163
    718
    Yes I always cleaned them, I had them on my car just over 2 years.
  40. v1raj
    v1raj Member
    295
    Had KW's on my old MK4 for over 2 years. Never once greased or taped them. Changed the height rarely and never gave me any problems.
    As advised, i wouldn't recommend getting budget coilies .. I doubt you'll be able to get much, if anything, once you've used them and try to sell.. A lot easier, and cheaper, to just save up a little more and buy a decent set.
