Need advice on JOM coilovers on my '97 Avant
V6SRS Apr 7, 2012
  1. V6SRS
    V6SRS New Member
    Hi Guys,
    I have just replaced the rear suspension on my 97 Avant. It previously had lowering springs on it, but had completely shot dampers.
    I have replaced the rear bushes and fitted a set of JOM coilovers. (Front ones waiting to be fitted)
    The coilovers came with no instructions and require you to reuse the top mounts and rubbers from the old struts.
    I am not completely sure I have them assembled correctly. There are at least 3 combinations of spacer/washer order I could have tried.
    Bottom line is they are rattling/creaking a lot and I am wondering if this is because of how I have assembled them.
    Anyone else used JOMs on the rear and if so can you tell me a) if they are noisy? and b) what what the assembly sequence on the top end?
    Hope you can help.
    Sean
  2. aragorn
    18,491
    855
    Jason.S on here used some cheapo coilovers and had the same clattering issue.
  3. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,163
    1,123
    I did not like the look of the prefacelift rear strut tops, so kind of happy i went over to facelift version.
    is that an option for you?
    facelift units are complete, no messing about with spacers or washers.
