Need a Single Mass Flywheel
docurley May 29, 2008
  1. docurley
    4,070
    85
    I need to get hold of a single mass flywheel for my 1.8TQ to go with a Southbend clutch I bought.
    If anyone can point me in the right direction I will appreciate it.
  2. Andy.B
    Andy.B Member
    401
  3. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    what about Southbend themselves? 10-12lb single mass lightweight wheels
  4. docurley
    4,070
    85
    Cost too much I'm on a budget as normal.
  5. dummi
    dummi smoking a6
    1,210
    i have a 2.7t fidanza doc is that any good
  6. Andy.B
    Andy.B Member
    401
  7. docurley
    4,070
    85
    I have no idea if that would fit a 1.8T I would suspec not but may be someone more in know would be able to chip in.
    Keep the sugestion coming guys and thanks
  8. jcb
    4,132
    13
    any lightweight one is going to be pricey. especially if bought over here
    all fidanza, southbend etc are around the $500 mark.
    whats your budget?
  9. Broken Byzan
    13,237
    465
    I bought my whole clutch and flywheel kit from them, around ££350 delivered with the stage 3 setup. Also they mark it as a warrenty replacement, it helps with customs etc
  10. docurley
    4,070
    85
    How much do I want to spend:think:............ nothing
    But for a budget £150.
  11. Biglockie
    Biglockie Aye you know it makes sense
    1,032
    This is gonna be one of my major purchases later in the year fellas so gonna keep an eye on this thread
  12. Siena
    Siena Active Member
    2,626
    V6 flywheel doesn't fit I4.
    8-bolt fitting, as opposed to 6.
  13. giorgos_cupra
    giorgos_cupra New Member
    21
    i'm getting an unorthodox flywheel to go with my stg4 southbend...They are pretty pricey.I'm getting one for 470 pounds.But it's the best of the best!
  14. dummi
    dummi smoking a6
    1,210
    thanks Siena. is the v8 8 bolt too?
  15. docurley
    4,070
    85
    Did you get hold of the guy you know for a price by any chance?
  16. Siena
    Siena Active Member
    2,626
    40V V8, with the exception of the RS6, have 8-bolt fitment.
    RS6 and all 32V V8 engines, have 10-bolt fitment.
  17. docurley
    4,070
    85
    Hummmm just found out that some TDI have a Single Mass flywheel as stock and wandered if this would fit and be up to the job?
  18. dummi
    dummi smoking a6
    1,210
    seriously? that doesn't make sense, which model?
  19. jcb
    4,132
    13
    it will be monster heavy on a TDi
  20. Tuffty
    Tuffty Member
    127
    www.ttvracing.co.uk if they don't list it, ask, as the website is in the middle of a revamp so hasn't been updated recently.
  21. Siena
    Siena Active Member
    2,626
    Will fit, but your engine won't run.
    The crank sensor air gap's in a different place on a TDI.
  22. docurley
    4,070
    85
    That put an end to that idea.
  23. Broken Byzan
    13,237
    465
    Our crank sensor runs from the gear inside the engine mounted on the rear of the crank, so no worries about sensors.
    I made enquires about some of the single mass conversions listed for A3's and TDi's etc some shops said they would work on an A4 and some said no. 100% the crank sensor poses no problem tho
  24. jcb
    4,132
    13
    surely it will be heavier? they run massive damper balancing units as well
  25. docurley
    4,070
    85
    Well it's too much of a gamble so I will look for one that I know will fit.
