Need a new turbo for 2.5tdi
BRILLO May 30, 2013
  1. BRILLO
    BRILLO Member
    140
    As above. Been having probs of over boosting for a while now ( code 00575 ) changed map sensor and now being told probably the turbo. It's 100,000 miles now and wondered if its worth cleaning with mr muscle or is it due to go anyway. It's just that I have the money just now for a turbo which isn't always the case. Where's good place to get them from and has a hybrid turbo got any benefit on a standard 180 q. Fancy remapping though.
  2. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    Drop Adam an email..
    tditurbos@gmail.com
    He will rebuild or upgrade/hybrid your tdi... I person I recommend
  3. dualmono21
    dualmono21 Well-Known Member VCDS Map User
    1,132
    a friend of mine has the exact same issue with exact same code
    id advise you take it for a spin and log the car whilst connected to vcds then post up the results
    i am going to put mr muscle into his turbo to see if if makes things better
  4. Audi Doodah
    Audi Doodah Active Member
    377
    35
    Mr muscle is defo worth a go. Much cheaper than going for a new turbo! If you have access to VCDS, perform output tests in Engine and one of the tests moves the actuator arm so you can observe it moving freely or not.
  5. abyrne153
    abyrne153 Member
    111
    You can test the actuator arm by removing the 2 10mm bolts that attach the actuator to the body of the turbo. Be careful not to drop them into the V of the engine as they can be tricky to get at. Once removed you can move the arm which should move freely. Any stickiness indicates the vanes are gummed up. Mr Muscle is worth a go. Remove the 3 exhaust flange bolts and pull the exhaust aside. Pump Mr Muscle into the exhaust side using a flexi tube. Put plenty in and work the actuator arm occasionally. You should find it beginning to free up within minutes. Leave for about half an hour and take for a good drive. Make sure and use gloves when handling Mr Muscle as it is very corrosive stuff.
    BRILLO likes this.
  6. BRILLO
    BRILLO Member
    140
    Ok guys. Cheers for the replies. Will be trying the mr muscle over the next few days.
