Need a new sump, will this fit?
coyle Mar 15, 2011
  1. coyle
    coyle From Show... to GO
    435
  2. S3KO4
    S3KO4 Member
    850
    second one looks very close to my apy sump
  3. coyle
    435
    its going on an APY
    i think the top one is meant to fit APY? as it lists just about every other 1.8t, and i think there the same?
  4. S3KO4
    S3KO4 Member
    850
    first one looks exactly like the one as well, but it will be lower grade of alloy alu.. which means could crack easier if you hit bumps etc
  5. Mpathe
    Mpathe 1st gear
    394
    the second one fits but cant see if the first one has the turbo return connection on it or not as im sure the a3's turbo return doenst connect to the sump
  6. coyle
    435
  7. S3KO4
    S3KO4 Member
    850
    they all have the same return oil pipe connection. it should work, and if you don't ever scrape your car then it makes sense to go for the first one.
  8. coyle
    435
    its been banged/cracked and welded by the previous owner, but the weld touches the sump plug, so that doesnt tighten properly, so it has a very small oil leak
  9. S3KO4
    S3KO4 Member
    850
    mine was the same I took it off didn't realise how bad it was so i put the same **** back on. I would go for the new one if your car has not been lowered etc.
  10. Dani_B19
    9,466
    435
  11. coyle
    435
    ok, so the 1st one at £40 which is new should be ok?
    if so i'll buy it now
  12. Jacko4130
    Jacko4130 Goodie Gum Drops
    848
    I had a sump of Ebay and its been fine, Paid £40 ish, Fitment was fine. Only thing was i cracked it when hitting a rock but that was my fault and got sorted with a line of weld.
  13. coyle
    435
    I went for the new non genuine sump in the end, and the seller asked for my car number plate,
    Ive had this email,
    Hi,
    I've done some checking and this is not the correct sump for your car. This 038 103603L the one you need is 038 103603M
    I will have to process a refund on this order.
    Many Thanks
    Graham
    is that right? i was under the impression it would fit?
  14. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    You can hit the blanking plate out, it still has the hole and threads for the sensor.... lol.
  15. <tuffty/>
    21,964
    4,238
    Ones I have seen don't have the fixing holes for the sensor drilled or tapped mate... can't speak for the copies but VAG ones don't that I have seen...
    The copies look ok but make sure you use proper VAG sealant any sump using anything else that I have seen leaks like a sieve... just buy one with a sensor hole....
  16. Welly
    10,696
    130
    Eh? I've got an AGU one at home, an OEM sump, with the holes etc? Weird...
  17. coyle
    435
    he asked if it needed the sensor hole or not, as he does both types..
    so i presume if i ask for the same sump i originally ordered, with the sensor hole, it will fit?
