Need A massive favour
SDO Jun 13, 2009
  1. SDO
    SDO Member
    153
    Hi
    guys need a favour i'm half way through doing my suspension fitted the back no problems. Came to fitting the front and hit a problem and this is where i need the favour i can't get the bolt on top of the strut off as i don't have a 21mm cranked ring spanner and can't get hold of one anywhere local.
    Is anyone willing to lend me theres so i can get it done long shot i know i'd be forever grateful. or does anyone know of other ways to get it off
    cheers
  2. Dani_B19
    9,058
    338
    Where do you live?
  3. SDO
    SDO Member
    153
    Nottingham just up from ikea
  4. Dani_B19
    9,058
    338
    Bit too far then.
  5. h100vw
    h100vw Member
    218
    Can you get an impact gun on it.
    Gavin
  6. SDO
    SDO Member
    153
    yeah but need an alan key in the top
  7. alijames
    alijames Active Member
    1,024
    A windy gun with a 21mm socket will undo the top mount easily without needing the allen key.
    However, as I don't have one, I made do with a 21mm Spark Plug socket which has a hex pattern for a spanner at the top, then I put the allen key through it. Works a treat.
    Cheers,
  8. Broken Byzan
    13,237
    465
    ^ What he said ^. I actually have a socket set with a hole straight through it and the ratchet so i can use a key through the centre. But the spark plug socket thing works well as a standby
  9. SDO
    SDO Member
    153
    cool cheers guys i'll give the sparkplug idea a try
  10. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    I welded a rod onto a spark plug spanner as a handle.
  11. fingermouse
    fingermouse thats me
    3,986
    111
    bit late but I filed the sides on a socket , held that with a spanner and the allen key went through the top
  12. Imteyaz
    Imteyaz 6th Gear
    535
    In the past when I've got stuck with things like this, I would drive over to our local friendly exhaust centre and ask the lads to stick their air gun on any nuts that need removing. Once loosened off, I hand tighten them back up and drive home (2 minutes away) and can then complete the job when I get home.
    I sometime have to drive back to the exhaust centre for them to tighten nuts up too but a couple of quids tip keeps them happy and makes the job much easier. Now I have a compressor I don't have to worry so much, just worth bearing in mind if you do get stuck sometimes...
  13. 666markyboy
    666markyboy Well-Known Member
    1,201
    49
    I did the same as fingermouse.... ground flats on a socket then used a large spanner or maybe you could grip it with molegrips
