Need a clip to fix your headlight self levelling system ?
sideways steve Feb 17, 2012
Thread Status:
Not open for further replies.
  1. sideways steve
    sideways steve Member
    347
    Ok, the silly plastic t piece things inside your headlights which attach the levelling motor to the lense are known for being **** and breaking. Its also known that you cannot buy these as spares either.
    I just had a conversation with Hella UK and as these light units are made for Audi they are not allowed to sell certain spare parts, one of which is this silly clip !
    I am in the process of drawing up the clips in 3D cad and am going to get a batch made up, probably in Aluminium.
    I wanted to see if anyone else would be interested in a pair ? due to the work involved I would imagine I could supply these for about £10 a pair. They will be slightly redesigned to make them stronger and hence prevent them from ever breaking again.
    Please add your name to this thread if you would be interested in a pair so I can see if its worth my while going out to various companys to produce them rather than me just making a pair for myself.
  2. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,825
    107
    S3 Paul
  3. S3featesV9
    S3featesV9 Active Member
    1,032
    12
    1) S3 Paul
    2) S3featesv9
    3)
    4)
    5)
    6)
    7)
    8)
    9)
    10)
  4. <tuffty/>
    21,572
    4,047
    If peeps would copy the list adding themselves if they are interested rather than individual names etc that would be cool...
    Steve, good to go for a group buy once you have enough interest... as for the material... any reason why you couldn't use nylon over aluminium?
    1) S3 Paul
    2) S3featesv9
    3) <tuffty/>
    4)
    5)
    6)
    7)
    8)
    9)
    10)
  5. <tuffty/>
    21,572
    4,047
    Just for everyones info... this has been approved...
  6. S3 Paul
    2,825
    107
    Good to hear,
    Its a part nobody makes and alot of people need.
    Not treading on anybodys toes and helping fellow owners into the bargin !
  7. superkarl
    superkarl MAN OF STEEL
    9,553
    2,453
    I managed to source some from megane headlights and supplied to as many people as i could, i still owe tuffty some which i promised. sadly I've not been able to get them recently, not even for my self, so what you're doing is excellwnt. Im down
    Karl
  8. sideways steve
    347
    good stuff :) Im not trying to make money, I just know how annoying it is since both mine have now broke so wanted to find a fix ! I could easily knock up a couple for myself from some scrap material in the workshop at my work but to do more than just a couple I will need to have them done outside hence where the cost would come in for material and labour.
    I will explore the options for using both nylon and alloy but I personally feel alloy ones will be far better as the nylon goes brittle in cold weather and I think thats one of the reasons the standard ones keep snapping. Alloy ones would probably outlast the rest of the car !
  9. sideways steve
    347
    Funny you say that as I spent some time looking round various cars at the breakers to see if they used the same clips, as many cars use Hella light units. The only car I found that had the exact same clips were 2000-2001 VW Polo's but most of them were broken or cracked too. I defiantly think making them in aluminium is the way to go.
  10. rhys1210
    rhys1210 Active Member Team Meteor Team V8 VCDS Map User Audi S5 quattro
    177
    25
    1) S3 Paul
    2) S3featesv9
    3) <tuffty/>
    4) rhys1210
    5)
    6)
    7)
    8)
    9)
    10)
  11. 45_CB
    45_CB 8L S3 BAM
    53
    This has sunk my heart as my Polo GTi had a broken one which caused the headlight to flicker, I got another xenon unit (not cheap) and put the new clip on, clipped in the motor... SNAP :( very bad times indeed! Tried so many things to sort it!
    I do NOT want the same with my S3 if the clips are the same :( made me hate the car!
    I'm down for a set 110%
  12. <tuffty/>
    21,572
    4,047
    Copy, paste, add yourself to the list... if you aren't on the list then you aren't coming in ;P
  13. S3 AUO
    S3 AUO Member
    201
    10
    Meanie! :asskicking:
  14. <tuffty/>
    21,572
    4,047
    Makes it easier for the OP rather than trawling through loads of posts..
    If you want in, get your name on the list... simples :)
  15. shariain
    shariain Well-Known Member
    1,182
    190
    See pm
  16. 45_CB
    45_CB 8L S3 BAM
    53
    1) S3 Paul
    2) S3featesv9
    3) <tuffty/>
    4) rhys1210
    5) 45_CB
    6)
    7)
    8)
    9)
    10) ​
  17. S3 AUO
    S3 AUO Member
    201
    10
    1) S3 Paul
    2) S3featesv9
    3) <tuffty/>
    4) rhys1210
    5) 45_CB
    6) S3 AUO
    7)
    8)
    9)
    10)
  18. MURRAYS444
    MURRAYS444 Member
    790
    Put my name down Steve i'll collect them whenever's good for you!
    (EDIT) I'll do that for you then :) <tuffty/>
    1) S3 Paul
    2) S3featesv9
    3) <tuffty/>
    4) rhys1210
    5) 45_CB
    6) S3 AUO
    7) scottm4
    8)
    9)
    10)
  19. ant schof
    ant schof Member
    163
    Hi Steve ,
    Just thought i'd mention i came up with a fix for this a few months ago . Basically if you take a plastic furniture block the type you use for screwing flat pack furniture together . Drill an 8mm hole down the centre 'the right bore for the ball end of the leveller motor' then on the top side of the block cut a 5mm gap with a hacksaw . The plastic is the perfect resistance to allow the motor to be clipped and unclipped without breaking yet maintaining a good grip . Finally make a countersink hole for the tork screw to hold your new clip onto the back of the lamp . Costs about 10p and a little time . The only thing you loose is the D shaped surround by the fixing screw ,
    but worked fine for me . Just my two pence worth , lol .
    Cheers , Ant
  20. S3featesV9
    1,032
    12
    I'd still prefer an aluminium one as its going to be a fix and forget scenario
    Grazam likes this.
  21. S3Zek
    S3Zek Member
    410
    Are these for both types of front lights? If so I would like a set please :)
    1) S3 Paul
    2) S3featesv9
    3) <tuffty/>
    4) rhys1210
    5) 45_CB
    6) S3 AUO
    7) scottm4
    8)S3Zek
    9)
    10)
  22. spencer-s3
    spencer-s3 2nd gear
    1) S3 Paul
    2) S3featesv9
    3) <tuffty/>
    4) rhys1210
    5) 45_CB
    6) S3 AUO
    7) scottm4
    8)S3Zek
    9)spencer-s3
    10)
  23. CRS3
    CRS3 New Member
    15
    Sounds like a common problem. Mines hasen't broke yet but i would be intrested in a set just incase. A problem i do have though is that the arm on the sensor that connects to the linkage under the car has broken (front and rear) right where the ball joint screws through it. I was wondering if there is a solution to fix these without buying new sensors as new ones are quite expensive.:unsure:
    1) S3 Paul
    2) S3featesv9
    3) <tuffty/>
    4) rhys1210
    5) 45_CB
    6) S3 AUO
    7) scottm4
    8)S3Zek
    9)CRS3
    10)
  24. CRS3
    CRS3 New Member
    15
    Sorry i was a bit late wit my post, revised:
    1) S3 Paul
    2) S3featesv9
    3) <tuffty/>
    4) rhys1210
    5) 45_CB
    6) S3 AUO
    7) scottm4
    8)S3Zek
    9)spencer-s3
    10) CRS3​
  25. S3featesV9
    1,032
    12
    You can repair the level arms, I used Araldite. Been solid Ever since, which was like year and half ago or longer
  26. CRS3
    CRS3 New Member
    15
    Sounds good but where they have broke, the bits are missing. I was thinking about shaping a small piece of thin aluminium with a hole in the end for the ball joint and attatching it with small screws and nuts.
  27. Gops
    3,198
    666
    1) S3 Paul
    2) S3featesv9
    3) <tuffty/>
    4) rhys1210
    5) 45_CB
    6) S3 AUO
    7) scottm4
    8)S3Zek
    9)spencer-s3
    10) CRS3
    11)Gops (if there's room for one more)
  28. sportstractor
    sportstractor Chugger
    2,709
    1) S3 Paul
    2) S3featesv9
    3) <tuffty/>
    4) rhys1210
    5) 45_CB
    6) S3 AUO
    7) scottm4
    8)S3Zek
    9)spencer-s3
    10) CRS3
    11)Gops
    12) sportstractor
  29. S3featesV9
    1,032
    12
    Probably best if you just buy a new one, yours sounds pretty shagged tbh
  30. StaceyS3
    StaceyS3 Well-Known Member
    2,505
    502
    1) S3 Paul
    2) S3featesv9
    3) <tuffty/>
    4) rhys1210
    5) 45_CB
    6) S3 AUO
    7) scottm4
    8)S3Zek
    9)spencer-s3
    10) CRS3
    11)Gops
    12) sportstractor
    13) StaceyS3
  31. Cees48
    Cees48 New Member
    10
    1) S3 Paul
    2) S3featesv9
    3) <tuffty/>
    4) rhys1210
    5) 45_CB
    6) S3 AUO
    7) scottm4
    8)S3Zek
    9)spencer-s3
    10) CRS3
    11)Gops
    12) sportstractor
    13) StaceyS3
    14) Cees48
  32. shariain
    1,182
    190
    1) S3 Paul<br />
    2) S3featesv9<br />
    3) <tuffty/><br />
    4) rhys1210<br />
    5) 45_CB<br />
    6) S3 AUO<br />
    7) scottm4<br />
    8)S3Zek<br />
    9)spencer-s3<br />
    10) CRS3<br />
    11)Gops<br />
    12) sportstractor<br />
    13) StaceyS3 <br />
    14) Cees48<br />
    15) shariain <br />
  33. sideways steve
    347
    Hey folks,
    Just to clarify, this is for FACELIFT headlights, I cannot tell you if they will be the same on pre facelift as I have not seen one from a pre facelift.
    I have managed to get hold of an un damaged clip and will be starting the drawing work on it this week. Hopefully by this time next week I will have spoken to a manufacturer and arranged to get some made and found out pricing etc so watch this space.
  34. S3-Sandy
    S3-Sandy S3 OFU
    86
    1) S3 Paul
    2) S3featesv9
    3) <tuffty/>
    4) rhys1210
    5) 45_CB
    6) S3 AUO
    7) scottm4
    8) S3Zek
    9) spencer-s3
    10) CRS3
    11) Gops
    12) sportstractor
    13) StaceyS3
    14) Cees48
    15) shariain
    16) S3-Sandy
  35. Metro
    Metro Error
    381
    I havnt got xenon lights, just the facelift standard projector ones, one of my dipped beams wobbles sometimes when going over a bump, will this be the clip that is causing this? Just wondering before putting my name down! Cheers
    Edit: before anyone says anything xD yes, the light are secured in and are solid in the holder!
  36. Dan-Jnr
    Dan-Jnr Well-Known Member
    1,234
    386
    1) S3 Paul
    2) S3featesv9
    3) <tuffty/>
    4) rhys1210
    5) 45_CB
    6) S3 AUO
    7) scottm4
    8) S3Zek
    9) spencer-s3
    10) CRS3
    11) Gops
    12) sportstractor
    13) StaceyS3
    14) Cees48
    15) shariain
    16) S3-Sandy
    17) Dan-Jnr
  37. sideways steve
    347
    This is a possibility yes, I believe the xenon and non xenon facelift lights use the same clip. It will ether be wobbling due to the clip being broken or the manual adjuster has popped off. The easiest way to check is to park against a wall and use your in car adjuster to move the lights up and down. If the wobbly light doesnt move up and down then its the clip thats broken.
    This of course is assuming you dont have self leveling and just have the adjuster beside the light switch on your car ? If you have self leveling you need to use vagcom and do an output test on the lighting system to make them move up and down.
  38. IrishDave
    IrishDave Active Member
    682
    45
    1) S3 Paul
    2) S3featesv9
    3) <tuffty/>
    4) rhys1210
    5) 45_CB
    6) S3 AUO
    7) scottm4
    8) S3Zek
    9) spencer-s3
    10) CRS3
    11) Gops
    12) sportstractor
    13) StaceyS3
    14) Cees48
    15) shariain
    16) S3-Sandy
    17) Dan-Jnr
    18) IrishDave
  39. Metro
    Metro Error
    381
    Yeah, they adjust with a roller by the light switch. I'll have a look thus evening cheers
  40. 45_CB
    45_CB 8L S3 BAM
    53
    SNAP !
    lol be careful
Thread Status:
