Nearside Drive shaft oil seal
B1GW1L Sep 10, 2012
  1. B1GW1L
    B1GW1L Member
    96
    Guys
    Anyone know where i can order a N/S Drive shaft oil seal from most garages have said its an audi dealer only part im hoping someone on here can advise me otherwise?
    Thanks in advance.
  2. Lewis583
    956
    91
    Have you tried the usual places?
    Eurocarparts/GSF/Andrew Page
    Can't see it being that expensive to be honest from main dealer
  3. Westy
    Westy Well-Known Member
    17,443
    1,103
    I've had non dealer parts before that don't fit correctly and just leak anyway. Get a dealer CV boot mate.
  4. Greg-S3
    Greg-S3 Active Member
    576
    67
    It won't be anymore than £20 from a dealer, it'll fit well and won't leak, after market oil seals aren't worth the trouble!
  5. B1GW1L
    B1GW1L Member
    96
    OKay so ill get it from a main dealer anyone know if theres a thread for fitting it yourself or would it be better to take it to a garage and get it done?
    I presume you need a ramp ?
  6. Westy
    17,443
    1,103
    You can do it on axle stands. I did mine. You need a spline tool to undo the bolts and a fair few extensions to reach the bolts where the shaft bolts to the gearbox. You will also need a CV boot too to do up the annoying clips.
    I broke my clip tool on the last CV boot and ended up just going to a garage. It's not the cheapest job labour wise but it's a bloody messy job. If you have all the tools, give it a go.
    fanta likes this.
  7. B1GW1L
    B1GW1L Member
    96
    To the garage it is then :)
