  1. monteiro
    monteiro A6 Avant 1.8T Sport Stage1
    Hi i have my car remap and i think i need a new n75, can I use a n75j on my K03 ??
    Is it safe??
    Thank’s
  2. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,775
    33
    You would have been better off replacing the N75 before you got a remap.
  3. monteiro
    I not sure if i need to replace the n75 or the DV valve i have log in to the vag.com and came this:
    17963 - Charge Pressure: Maximum Limit Exceeded
    It was runing well before went in to limp mode for 3 minutes then went back to normal
    I was driven at 50 mph :crying:
  4. Geeman
    Geeman Low Life
    1,318
    I have both a perfectly working N75 valve (in fact I have two)... and an atmospheric adjustable dump valve if you're interested.
  5. monteiro
    the car has only be remap once i have log with the vag and din't came with any faulty codes, but i may need to replace the dv valve because im using the OEM one .
    thanks any way for the help :thumbsup:
  6. aragorn
    18,444
    848
    Could just be a bad map, who did it?
    I wouldnt fit an N75J unless the map is designed for it, although a new N75 might be useful if its overboosting just to rule it out.
  7. monteiro
    so far so good no more faulty codes the car was remap by ecu-evolution the map is a good map, will it be ok to fit a n75j will the standart k03?? :think:
  8. Broken Byzan
    13,237
    465
    The J valve can cause boost spikes that cause limp mode. It is commom to map the car without the J valve and fit that afterwards to possibly increase the boost slightly. The boost comes in harder and spikes higher,but drops off quicker. I didint like the feel of it and went back to an F valve, suited the map better.
    Is your car DBW? or does she have a throttle cable?
  9. monteiro
    my car is DBW its fine now but im going to replace the DV valve any way :faint:
