N75 valve.
BRILLO Apr 29, 2013
  1. BRILLO
    BRILLO Member
    140
    Is there anyway of testing these to find out if its faulty?
  2. czm
    czm Member
    266
    19
    Vcds?
  3. jimmcgee
    jimmcgee Active Member
    257
  4. Audi Doodah
    Audi Doodah Active Member
    377
    35
    As above. A registered verion of VCDS?VCDS Lite allows you to run engine output tests, n75/actuator being one of them. Good way of checking turbo vanes are clean as you can see smooth movement of the actuator arm.
  5. BRILLO
    BRILLO Member
    140
    Cheers guys. Had it scanned last week. Was pointing to boost pressure sensor in intercooler or n75. Changed above sensor and no change. Vcds guy now on hols so will probably need n75 as well. I can hear it making a noise as if its not sealing when driving.
