n75 valve talk to me
jaymodunn Mar 20, 2014
  1. jaymodunn
    jaymodunn Member
    123
    o.k which vavle for my audi a4 1.8t quattro ajl, as i can't find it, and where to buy, cheers
  2. jaymodunn
    jaymodunn Member
    123
    anyone around...
    i have located it but how the f do you remove it as i can't get to it..
  3. Bradderz_1988
    3,958
    240
    TPS is around £30 iirc
    Best way of doing it is by removing the airbox followed by the Puck valve then you should have enough room/movement in the intake pipe to remove the N75 valve, whrn i swapped mine out i pulled the pipes off the turbo/wastegate then swapped them to the new one of the car, make a note which pipe goes where before you remove it.
    Part number :- 058906283F
  4. jaymodunn
    jaymodunn Member
    123
    cheers i own a fwd 1.8t a4 as well and was going to swap them over to test but looks like that can't be done. cheers
  5. Bradderz_1988
    3,958
    240
    Whats your thinking as to why there not interchangerable ??
    There exactly the same part !!
  6. jaymodunn
    jaymodunn Member
    123
    something about to remove it you cut the pipe.
    The problem i have is i can't find a diy i have ordered a Haynes manual, but don't want to start and not finish. but if you say i should be able to take it off and put it back on i will give it a shot. cheers
    I have got to the part how do you remove the metal clips
  7. Bradderz_1988
    3,958
    240
    Just pull the pipes whilst rotating then and they should work free.
  8. jaymodunn
    jaymodunn Member
    123
    you make it sound so easy consireing the space and how tight they are clamped it is impossible. i am going to buy a clip untightener
    edit now off what an **** and i have nicked one of the pipes so will wait for a new one to fit. thanks for the assistance.
  9. jaymodunn
    jaymodunn Member
    123
    put new one on now says n75 open have i put it on wrong or is it faulty?
    showing as same fault now tried again this is pissing me off now.
  10. Sulli79
    Sulli79 Active Member
    541
    37
    Have you checked the wiring? Especially around where the wires enter the plug?
  11. jaymodunn
    jaymodunn Member
    123
    yes it looks good. the problem is it is made out it is easy to replace when in reality it is a pita. I haveb worked on french cars and they are easier to work on then audi. I could spend forever trying to fix it so selling it at a loss, just want rid when i read up it could be loads of different things.
  12. aragorn
    18,545
    865
    wtf?
  13. jaymodunn
    jaymodunn Member
    123
    just venting, i want to get the car working but i think it might be a dud so might but my losses and try and get better quality one.
  14. aragorn
    18,545
    865
    Assuming its brand new its unlikely to be faulty.
    Its probably broken wires in the cable leading to it, i've had that before. No damage was visible. I cut about 8 inches off the cable and spliced in 8" of new wires and a new connector.
  15. jaymodunn
    jaymodunn Member
    123
    TBH I might have knicked the pipe on the right hand side, could this cause issues. Also is the n75 always related to the valve, could it be elsewhere?
  16. aragorn
    18,545
    865
    Depends on the exact fault code, but if its saying the valve is open circuit, then its the valve or the wiring.
  17. jaymodunn
    jaymodunn Member
    123
    got it booked into a garage to have a look and hopefully fix problem, i hope ir isn't critical, the turbo does seem to whine a bit, but i have been looking at k04-015 in case.
  18. jaymodunn
    jaymodunn Member
    123
    o.k the garage says wiring fine boost and turbo spinning but could be siezed dump valve or something else.. how easy to replace?
  19. aragorn
    18,545
    865
    you have a fault code for N75 open circuit.
    Thats not caused by a siezed dump valve, its caused by an open circuit on the N75. That can only be caused by two things. 1) a broken N75. 2) broken wiring.
    Dump valve is cheap and easy to replace, they're about £25 from the dealer (get the TT225 version as its stronger) But i doubt thats whats wrong here.
