N75 valve problem
benashley Apr 26, 2014
  1. benashley
    benashley Member
    59
    I have an S3 APY engine code and I seem to be having some N75 valve related issues.
    The problem im having is that current my car seems very sluggish between 2-3k rpm and the power seems to fluctuate very slightly then at 3200 rpm I get boost all of a sudden. If I unplug the N75 valve I get a nice constant boost delivery from 2.3k ish.
    I swapped my N75 valve for one that I had laying around which was good when it was removed around 8 months ago. The car boosted much faster and harder and there was a noticeably more boost than before but at 3k the boost started to splutter badly then clear after.
    The N75 valve originally on the car is a 06a906283e and the one I replaced it with was a 058906283f.
    After doing some searching the F type seems to be the one I should have but I cant seem to find anything about the E type (or at least not with the same part no.)as to whether its the correct one for the car.
    Any help would be much appreciated. Thanks
  2. Gops
    3,198
    666
    06a is the one you need I'm sure..
  3. Joshstan
    Joshstan Member
    180
    17
    I am running an E revision n75 on my s3 APY and it gives me no problems at all and was running the very same one on my AGU golf
    I think the differences are very slight it is basically an on off switch after all
    As to loosing power in the rev range I would first off scan the old girl for fault codes
  4. benashley
    benashley Member
    59
    Are you sure? Everything I have read seems to suggest I should have an F type.
    I think what im experiencing is compressor surge with the F type N75
  5. Freeman_1986
    Freeman_1986 Member
    169
    21
    I thought it was in my head....
    But I broke the 06e one and replaced it with the revision. And now it doesn't feel as quick...
  6. benashley
    benashley Member
    59
    So you had an 06a906283e one on yours? What did you replace it with?
  7. Joshstan
    Joshstan Member
    180
    17
    A little bit of research suggests the standard is a C revision and the F revision being a direct update from that so basically we should have c or f a little more digging results with the J revision being suggested as an upgrade
    Now my head is spinning lol
  8. benashley
    benashley Member
    59
    Lol apparently they all deliver boost slightly differently?
  9. benashley
    benashley Member
    59
    06a906283e is apparently the latest revision of the C/F type.
    I checked for fault codes aswell and the only fault I have is the incorrect flow fault from having no sas
  10. <tuffty/>
    21,143
    3,832
    Scanned for fault codes yet? don't assume the N75 is at fault especially if its giving you boost after its alleged 'hiccup'...
    The N75 is most likely doing as its told... you need to log the car to confirm...
    Its plausible that an over boost problem has happened and the ECU has cut N75 duty and dumped boost to protect the engine then brought it back in again hoping the issue has cleared..
    Unplugging the N75 electrically doesn't prove its faulty...
    Is your car mapped? do you have a boost gauge? what boost are your seeing if so?
  11. benashley
    benashley Member
    59
    No fault codes except incorrect flow fault from sas delete.
    The car is supposed to have a stage 1 map but there is no proof of this.
    The car has had new coil packs(Bosch), New Bosch MAF, New green water temp sensor(genuine), full service with new plugs (BKR7E) and a new Bosch lambda sensor. All within the last month for various reasons. Also has had all the usual stage 2 stuff FMIC, 80mm TIP, 3" system with milltek rear box.
    But the problem has been there since I owned the car (before the mods).
    I have also pressure tested everything from the throttle bodie back to the TIP and there are no leaks anywhere.
    Now im ready for stage 2 map I thought I should try and cure it but maybe it just needs mapping?
  12. benashley
    benashley Member
    59
    I dont have a boost gauge fitted and im unable to log as my laptop isnt working. I have the tourque app on my phone which displays boost etc. But I dont think I can log with it or how accurate it is.
  13. Gops
    3,198
    666
    Well my car has the 06a
  14. benashley
    benashley Member
    59
    Yeah I have since found that the 06a is the latest revision. Thanks
  15. benashley
    benashley Member
    59
    I should be able to do some logging by the middle of the week. What do I nedd to log?
    I have just spoken to the previous owner and apparently it was remapped by superchips.
    Went for a drive earlier and when you accelerate part throttle from 2k upto 3k you can feel the boost fluctuating
  16. badger5
    9,471
    1,988
    003,115,118 worth logging
    AND
    002.020.118
  17. benashley
    benashley Member
    59
    Thanks. Want to get it sorted then hopefully to you for stage 2 ☺
  18. benashley
    benashley Member
    59
    Checked my fault codes again today and I got P0571 brake switch unplausable signal. My snap on solus pro also thinks that the brake pedal is depressed when it isnt. I doubt this has anything to do with my boost issues but I have ordered a new switch anyway.
    Laptop is now fixed so hopefully get time to do some logging tomorrow
  19. benashley
    benashley Member
    59
  20. benashley
    benashley Member
    59
    I think I have done it correctly but not 100%. I might get a chance to do some more later.
  21. benashley
    benashley Member
    59
  22. benashley
    benashley Member
    59
    Anybody?
  23. ShaunS3
    ShaunS3 Yorkshire & Humber Rep. Regional Rep VCDS Map User
    1,178
    215
    Logging wants to be done in 3rd gear, 2000rpm right through to 7000rpm in one continuous boost......needs to be a very long, straight and clear road ideally (private of course ;) )
    Shaun.
  24. benashley
    benashley Member
    59
    Thats what I did above. Have I done it wrong?
  25. ShaunS3
    1,178
    215
  26. benashley
    benashley Member
    59
    Thats probably because I didn't stop logging as soon as I had done the run. I will try and do some more later but the people that know what there looking at with regards to the logging are allways really busy
  27. badger5
    9,471
    1,988
    I dont open .zip files...
    post the raw data here with tags to view if you want them looked at
  28. benashley
    benashley Member
    59
    I tried that and it said it was the wrong type of file.
    I didn't mean to sound rude saying people like yourself are allways too busy ;-)
  29. benashley
    benashley Member
    59
  30. benashley
    benashley Member
    59
    second set 003-115-118
    http://i823.photobucket.com/albums/zz155/benrashley/Mobile Uploads/log6_zps1rinmrhs.png
    http://i823.photobucket.com/albums/zz155/benrashley/Mobile Uploads/log7_zpsufk1ax1k.png
    http://i823.photobucket.com/albums/zz155/benrashley/Mobile Uploads/log8_zpshn7be8ao.png
    which gave me
    Address 01: Engine Labels: 06A-906-032-APX.clb
    Control Module Part Number: 8N0 906 018
    Component and/or Version: 1.8L R4 5VT 0003
    Software Coding: 05610
    Work Shop Code: WSC 06313
    VCID: EED3A83AAA37886EF6F-517A
    3 Faults Found:
    17840 - Secondary Air Injection Solenoid Valve (N112)
    P1432 - 35-00 - Open Circuit
    17963 - Charge Pressure
    P1555 - 35-10 - Maximum Limit Exceeded - Intermittent
    16955 - Brake Switch (F)
    P0571 - 35-00 - Implausible Signal
    Readiness: 0000 0000
  31. benashley
    benashley Member
    59
    can do some more if needed. Thanks
  32. benashley
    benashley Member
    59
    Edited so you can actually see the pics. Thanks
  33. benashley
    benashley Member
    59
    Anybody? Really want to get this sorted. Thanks
  34. benashley
    benashley Member
    59
    Bump
  35. shan00ble
    shan00ble Member
    211
    What happened? @ 2480rpm
  36. benashley
    benashley Member
    59
    Which run? Thats around the point it starts to get kinda jerkie then clears just after 3k
  37. shan00ble
    shan00ble Member
    211
    First run. The flow seems to drop quite a bit ??
  38. shan00ble
    shan00ble Member
    211
    But may be because you let off the throttle and thus flow was reduced.
  39. benashley
    benashley Member
    59
    Yeah thats a gear change. Thats only there so you can see the headings for the columns
  40. shan00ble
    shan00ble Member
    211
    Aah okay... woops sorry
