n75 to actuator hose
jonny87 Feb 16, 2010
  1. jonny87
    jonny87 Active Member
    1,094
    so as some may remember when i first bought my car it had an mbc plumbed in between the actuator and n75 valve
    obviously i removed this straight away and as a temporary fix i used a plastic connector to join the two ends of the hose and clamped with small jubilee clips, not ideal but was best i could do at the time
    now i want to replace the whole hose to eliminate any chance of leaks etc the hose itself has bends formed into it at certain intervals to follow the contours of the engine etc so rather than buy a normal length of hose and try and clip it to follow the same contours i was wondering if i could buy the proper hose with the bends formed in, dealer maybe? or would it be best to find an s3 breaking?
    hope that all makes sense lol
    cheers
  2. <tuffty/>
    21,139
    3,827
    Either use a bit of silicon pipe or just order the proper one from an Audi dealer. Shouldn't be that expensive either way tbh...
  3. jonny87
    1,094
    wasnt sure if audi would sell something like that, bit of an odd request really but i suppose they must perish from time to time
    watch this space for a price from audi, possibly something outrageous!
  4. <tuffty/>
    21,139
    3,827
    A popular misconception, as far as I am aware, they list more or less every single part that goes into making a car (they may not have it in stock but can get it)
    Personally I would always at least ask Audi if they can get a part and for a price before trying to find it cheaper... Audi pricing can be a bit bizarre at times but you may be pleasantly surprised how cheap certain parts are
  5. Welly
    Welly VX220 SC Driver :)
    10,696
    127
  6. Westy
    Westy Well-Known Member
    17,443
    1,103
    FPR pipe is 3mm but I got away with using 4mm. It was a bit loose on the connector to the fuel rail but some clamps seem to have made it tight enough.
    Is it easy enough to replace the hoses from the n75 valve?
  7. Welly
    10,696
    127
    FPR outlet is like a gnat's cock though to be fair! lol.
    4mm should be nice and snug on the N75, it's about the internal diameter of the original pipe. N75 hoses are easy enough to change - the one from charge pipe to N75 is very easy, actuator hose is a bit more fiddly as access isn't great, but not impossible.
  8. jonny87
    1,094
    yer but the standard hoses have a very thick wall, 3 or 4mm id say
    the silicone hose is probably only 1 or 2mm?
    would make sense to replace like for like, unless of course the hose is stupidly expensive from audi of course
    ive already replaced the fpr hose and dv hose (when doing n249/n112/sai)
  9. Welly
    10,696
    127
    That said, it's only ever got to carry enough pressure to open the wastegate so a thick msidewall not 100% needed. Actuator pressure is only about 6-8 psi actuator dependent. The boost hose from the charge pipe to the N75 carries full boost pressure (20 ish) and mine has always been fine mate, no problems.
    But it's up to you duderama! Whatever you're happy with.
  10. jonny87
    1,094
    duderama? that a new un :)
    i think its going to be price dependant, il get my mate to get me a price from audi and go from there
    i wouldnt even like to guess how much it would be from audi, could be a fiver, could be £50 :faint:
  11. Welly
    10,696
    127
    lol, new 'n improved....
    If a PCV hose from Audi is 20 bucks, which it is :faint:, I'd be interested to see how that hose compares....
  12. jonny87
    1,094
    right well i went to audi, their diagrams only showed two hoses coming off the n75 valve, they ordered both that were showing in for me and neither were right, one was way too short the other looked like a flipping coolant hose!! so all in all pretty damn useless (those two hoses were £20-25 each)
    so i guess il just have to make do with some silicone hose, 4mm id?
  13. Welly
    10,696
    127
    4 MM ID will do the trick for you, and be nice and snug!
  14. jonny87
    1,094
    sweet, cheers mate
