N249 delete?
Colly Jun 2, 2012
  1. Colly
    Colly Member
    282
    can anyone tell me the advantages of the n249by pass?
    also whats the point in it?
  2. vrbob
    vrbob Thats no Moon, Thats a space station!
    2,375
    171
    Check the stickies mate its covered in there
  3. Gops
    3,198
    666
  4. marty.h
    marty.h Member
    124
    just done mine here is a pic showing it have much better throttle response
  5. <tuffty/>
    21,776
    4,165
    The N249 bypass achieves a few things... it tidies up and removes a lot of pipes that have the potential to split and leak, improve the DV's response on lifting the throttle and generally clean things up especially if you are looking to tart up the engine bay a bit...
    That said... bypassing the N249 then removes the ECU's ability to dump boost if it thinks there is an issue somewhere... N249 intervention tends to happen more on mapped cars than std ones... if bypassed and the ECU tries to dump boost (it will also throttle cut to an extent too) but can't due to the N249 not being in control of the DV then you will see a 'N249 mechanical failure' fault code...
    The ECU also uses the N249 to improve part throttle response IIRC... not sure to what extent as my car has not been std for some time but the effect varies depending on circumstance and level of tune...
    If you don't have to by pass it then there is no real advantage to it but on higher power stuff (bigger turbos and hybrids) then generally its binned off :)
  6. vrbob
    2,375
    171
    Tuffty you really are an 8L Guru i bow down to your wisdom
    So may well hold off removing mine for now and just do the B5 V2 Tip instead
    vivalacoulter likes this.
