Hi there i was about to do a N249 Bypasson my car but i cnt figure it out, due to a different layout than the earler models , can any one help? thanks
DREW
Basically you disconnect the vac line from the n249 that is connected to the inlet manifold. Then disconnect the vac line above the dv. Once you've done this connect the new vac line from the dv to underneath the inlet manifold where the n249 vac line was once connected
