N249 bypass on 2003 BAM help
T3 BRL Oct 30, 2012
  1. T3 BRL
    T3 BRL New Member
    23
    Hi guys slightly confused from this post
    N249 Bypass How To (2000 S3 - but same for many)
    if my car is a BAM then can I just straight through the pipe from DV to the pipe to the inlet manifold??
    Any help appreciated guys
  2. olethalb
    olethalb Active Member
    357
    77
    yes, remove / blank n249 pipes and leave it plugged in to loom. run single vac line from inlet to dv
  3. T3 BRL
    T3 BRL New Member
    23
    Cheers mate.
    Also where is best to run vac for boost gauge?
  4. olethalb
    357
    77
    fpr vac line is a popular option. i deleted all gubbins from my bay so had a spare vac port on the inlet mani so used that.
  5. Yohan87
    Yohan87 Guest
    For me I like the idea of the FPR having its own dedicated vac line.
    As above though, I used a spare vac port from under the inlet mani because I removed all the **** that wasn't required.
  6. T3 BRL
    T3 BRL New Member
    23
    Any pics for above guys?
  7. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,305
    375
    N249 bypass is just bypassing the N249 with a single 4mm ID length of hose from the inlet manifold to the DV. If you want a boost gauge then T into this new length of hose
