mystery overheating, please help????
alistair666 Oct 11, 2008
  1. alistair666
    alistair666 Member
    80
    hi guys
    having a prob with my 2000 a3 1.8t sport
    noticed my dash temp gauge wasnt reading so changed the sensor
    and thermostat. Changing the thermostat i jost nearly all of the coolant, i filled it back up but now im having overheating problems
    car rises to temp as normal but gauge sticks at 90oc as if showing a false reading, fans dont come on and if left will boil. Have done the aircon code 51 check and that sticks at 90 as well. noticed the bottom hose comeing from the thermostat going to the rad stays cool all the others are hot
    had the water pump changed with the cam belt a few months ago
    thinking probably an airlock but not sure why gauge or fans wont work
    any help greatfully recieved
  2. golf
    golf ***** rent boy VCDS Map User
    1,556
    Could be an airlock or the thermostat is not working as it should, assuming the water pump is still OK.
  3. Clach
    Clach A3 - 1.8Ts
    971
    try the heaters, if thet get colder instead of hotter..it's the water pump
  4. Broken Byzan
    13,237
    465
    Either stat not opening cos its faulty or because is airlocked and not getting heated by water to operate correctly.She needs bleeding, i am not 100% where to bleed an A3 without checking, but i bet it via a heater hose the same as an A4
  5. alistair666
    alistair666 Member
    80
    cheers guys
    im am getting hot air out the heater vents gonna take out the stat and check it in hot water
    could still do with some help with bleeding air out the coolant
    still a bit confused as to why the temp gauge just goes up to 90oc
  6. abdus
    abdus Top Gear VCDS Map User
    1,827
    just try removing any air locks before anything else. while still cold, remove coolant expansion bottle cap, start engine, put blowers on full blast and leave it for some time.
    you should be able to see some bubbles coming out if there is any air lock.
