MY2010 Car required for LED bulb testing
t8ups Apr 8, 2013
  1. t8ups
    t8ups Site Sponsor Site Sponsor VCDS Map User
    1,967
    686
    Hi Guys.
    I require someone local to me for me to test a LED that I have designed for the MY2010 cars to be plug and play and error free.
    THE CAR NEEDS TO BE A 2010 OR 2011 CAR PLEASE
    if someone is able to assist then please write in here and I will contact you, It will only take about 15 mins to see the fit of the bulb and to make sure that error don't come up before I send off for the final mould.
    Thanks in Advance.
    Trups
    K.A likes this.
  2. Wicked666
    Wicked666 Active Member
    584
    35
    Unfortunately I'm in Leeds but I'm looking forward to these :)
  3. kayemill
    kayemill Active Member Team Nardo Audi RS3
    273
    150
    43
    Would like to help but Scotland isn't exactly local to you!
    Hope you find someone soon.
  4. mjr901
    mjr901 Parts Manager - (Main Dealer) Gold Supporter Audi S3 Audi Main Dealer
    3,585
    1,053
    I'm 82 miles away :(
  5. t8ups
    1,967
    686
    Getting closer then...... :)
    if hinkley is closer then I can be there?
    Trups
  6. mjr901
    3,585
    1,053
    70 miles away.... :keule:
  7. TommyMac
    TommyMac Member
    92
    Pm sent
  8. oneniner
    oneniner Member
    77
    If you get stuck let me know. Hinckley isn't too far for me.
  9. Chris Coates
    Chris Coates Member
    97
    what leds mate? i have a 2010 but as you know im in the land of OZ:(
  10. t8ups
    1,967
    686
    Chris, i need the car local to me to test the fit etc so i can get the design right before i get my mould made which costs alot so it needs to be right and it needs to cancel that silly error.
    This fix will work in the B7 also.
    Trups
  11. t8ups
    1,967
    686
    PM me.
    if your not too far we could meet at the weekend for about 2pm?
    as long as any of your B7's have the Full DIS it will be perfect to test in also.
    Trups
  12. L1ARR
    L1ARR Active Member
    424
    43
    Trups,
    How did you get on with a test car? Do you have any results?
    Rich
  13. t8ups
    1,967
    686
    Rich.
    Had a B7 over and tested them, seem to work and also keep the error off but the car that came in had a brake light out so was hard to tell as I would of liked a car with no errors.
    another member has a B7 and he is going to meet me on weds for another try out and hopefully goes well.
  14. L1ARR
    L1ARR Active Member
    424
    43
    Great to hear, thanks for the update.
  15. t8ups
    1,967
    686
    Met up with forum member oneniner today, he came in his mid registered 2010 A3 black edition.
    The bulb I have made has worked ERROR FREE
    I just need to make up the final piece to send to the factory and get some testers made but looking good so far Guys.
    This bulb will then work on Any A3 8P and B7 regardless of build date.
    Trups
    AndyRST likes this.
  16. dzTT
    dzTT Active Member
    333
    29
    Sounds good, cant wait to get some of these..I'll keep a close eye for them being ready to buy :icon_thumright:
  17. TAPNET
    TAPNET Member
    89
    Oooooh exciting!
  18. DJ-S3
    DJ-S3 Active Member
    690
    43
    Looking forward to some pictures :D
  19. t8ups
    1,967
    686
    Pics i will try and get in a few weeks of what work i have done.
    Trups
    DJ-S3 likes this.
  20. poli84
    poli84 Member
    425
    57
    Good work Trups, looks forward to seeing the finished product.
    Just to clarify, what exactly have you created?
    Is it an LED which fits into the OEM housing or is it a new housing containing LEDs?
    Or is it a wiring loom which enables the OEM A5 LEDs?
    If it is a replacement LED, how bright are they compared to OEM A5 LED and the eBay ones which light up the entire space behind the car?
  21. t8ups
    1,967
    686
    Poli.
    Good question.
    Its a LED Bulb that will fit into the OEM halogen housing.
    I have designed it so it will be plug and play so you don't have to remove trim panels to fiddle with the wiring.
    the OEM LED units have 2 3528 LED's on them, the light is spread out across the plate as the lense is melting for it to aim the light.
    I have on my bulb 4 x 3528 LED's evenly spread out on the bulb so we can get the plate lit nicely and as close to the OEM finish as possible.
    once I have the bulb back from my mate who does the CAD drawing for me I will get a pair fitted to my car so you can all see the light spread.
    Trups
    a6_chris likes this.
  22. L1ARR
    L1ARR Active Member
    424
    43
    Great news on this,
    Don't forget to update everyone as I am sure you will be busy with orders.
  23. poli84
    poli84 Member
    425
    57
    Thanks Trups, sounds excellent.
    Looking forward to your finished work.
  24. t8ups
    1,967
    686
    Got hold of a company that sell the part that makes the bulb work error free, ordered 4 bulbs and tested them in a B7 which also has the same problems as the 2010 A3's. All working error free.
    i have asked that supplier if there will always be a supply and if it will be the same all the time as if its differant in the slightest it can mess the bulb up.
    i am waiting on my bulk buy discount code and will be ordering and sending the final pieces off to the factory for build.
    Trups
    Wicked666 likes this.
  25. Aidy06
    Aidy06 Member VCDS Map User
    412
    19
    Any pictures of them in the B7 mate?
  26. t8ups
    1,967
    686
    will post some on friday, i have been sent them, all you can see is the plate as its dark.
    Trups
  27. t8ups
    1,967
    686
    K.A, XTerminator and L1ARR like this.
  28. L1ARR
    L1ARR Active Member
    424
    43
    As per usual Trups a result and they look good, bet you will have a list longer than your arm.
    Put me down for a set.
    Rich
  29. t8ups
    1,967
    686
    Yes i have, still testing on that car.
    Will keep you all updated.
    Trups
  30. L1ARR
    L1ARR Active Member
    424
    43
    Cheers Trups
  31. Def-87
    Def-87 B7 2.0 TFSI Quattro
    46
    Good work t8ups. I will defiantly be purchasing a set. Any idea on prices roughly?
  32. marksolesbury
    marksolesbury New Member
    20
    Know you know I'm 5 miles away with a 2011 A3, happy to assist if needed.
  33. danb986
    danb986 In awe of VCDS Team Daytona
    518
    58
    I'd like to register my interest too.
    How is the 2010 different to the other model years out of interest?
  34. eastern_s3
    eastern_s3 New Member
    25
    Hi Trups, I've been following this thread closely from Australia. Do you have an ETA on when these will be ready for the MY10 8P?
  35. TAPNET
    TAPNET Member
    89
    Any update on these yet?
  36. t8ups
    1,967
    686
    Hi Guys.
    Quick update for you all.
    So, the test bulb has been in the A4 (a couple of posts up) for over 2 months now and no errors reported back to me, had a problem a week later with the "fix" I put in place to stop the error but I replaced the offending part and no problems since.
    The fix that is in place for this bulb is simple and is trick, if it was to go wrong on your cars then it will take you 2 mins to fix if that your self so there is no need to return for a replacement.
    The final piece has been made and I have asked for 2 pairs to be sent to me for the end of this week so hopefully I can get them in and if any trimming is required of the bulb then this will be done before I order the 1st batch.
    My Aim is to have the 1st batch ready for sale in the 1st week of SEPT. This bulb has been designed to work in the OEM halogen lamp housing, if you have any other housing then this will not fit.
    Hours of work have gone into making this with testing and buying parts in from around the world to get to this stage so just bare with me on the last hurdle and I will have this sorted for you guys with the 09 cars, remember this will be plug and play, no resistors, no removing trim to fit resistors etc.
    Trups
    L1ARR, Dean_T and danb986 like this.
  37. t8ups
    1,967
    686
    Delivery of samples will be here today as per my tracking numbers. will get some pictures up this week and get a list together so we can start getting them in.
    Trups
    Dean_T likes this.
  38. avvy786
    avvy786 Member
    55
    put me down for a set t8ups
  39. Def-87
    46
    Put me down for a set aswell please
  40. t8ups
    1,967
    686
    Why do you need a set? you have OEM ones that work error free.
